Is the 02 sensor signal the oxygen sending unit?
Old 03-12-2007, 07:53 PM
chillcat
chillcat's Avatar
Default Is the 02 sensor signal the oxygen sending unit?
I'm installing an air/fuel digital guage and it requires me to tap into the "signal wire on factory oxygen sending unit"--according to instructions. I want to be sure I'm using the right wire off my ecm. on the ecm-its row D7 purplewire. thanks
Old 03-12-2007, 08:51 PM
C4Techie
C4Techie's Avatar
O2 = Oxygen.
Old 03-12-2007, 09:01 PM
GS977
GS977's Avatar
i have mine hooked to the purple wire off the o2 sensor.
Old 03-13-2007, 07:24 AM
chillcat
chillcat's Avatar
ok cool...Thats the wire I thought it was. Hard to believe that wire will tell you whether your running rich or not...
Old 03-13-2007, 04:19 PM
RRT vette
RRT vette's Avatar
Yep, tie into the purple wire for the O2 sensor.
To Is the 02 sensor signal the oxygen sending unit?
Quick Reply: Is the 02 sensor signal the oxygen sending unit?
