Passenger Front Tire Uneven Wear
Old 01-15-2007, 06:57 PM
bradf_nc
bradf_nc's Avatar
Default Passenger Front Tire Uneven Wear
My Passenger side front tire is suddenly wearing really fast on the outside. All the other tires are in good shape but the passenger front is wearing really fast on the outside and the treads are wearing faster on the back of some of the treads than on the front of the tread. Have any of you had this problem?What was the cause?
Regards,Gary
Old 01-15-2007, 07:31 PM
Kinkajou
Kinkajou's Avatar
It can be as simple as low or high tire pressure, or can be wheel + tires not balanced , but a misalignment is usually the culprit.
Old 01-15-2007, 07:43 PM
BADDUCK
BADDUCK's Avatar
Location: One day you're a Comet...the next day you're dust... Arkansas
Regards,Gary
I'm not sure what you mean by "back of some of the treads", but it sounds like a toe-in problem. Get a front end alignment check and rotate that tire to the rear for better handling.
Old 01-15-2007, 07:44 PM
Defender337
Support Corvetteforum!
Defender337's Avatar
wheel alignment should do the trick. I had the same problem on my driver side front tire.
Old 01-15-2007, 10:30 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
I agree on an aligmnemt being needed; then rotate front & rear so you can "even them out"...
To Passenger Front Tire Uneven Wear
Quick Reply: Passenger Front Tire Uneven Wear
