Overheating problem 92 LT-1 stock
Location: Sunny Seaside Seabrook Texas (a whole 'nother country)
1 Post
Hi Guys -
I've got a 92 stock LT-1 and my temp is rising at idle on a cool day (no A/C) to 220! When running 30+ mph it drops to 190 area. Is there a cooling fan for idle speed? or a fuse for a cooling fan that can be checked? or some way I can check problem? The coolant level is good along with the level in the overflow bottle. The car only has 19000 miles and everything seems to be in great shape...
Thanks in advance,
Thanks in advance,
St. Jude Donor '06
Originally Posted by Ruby18823
Sounds completely normal to me. I believe that, if stock, the thermostat opens at 190, and the fan kicks on at 228 below 30 mph.
Originally Posted by sk8r20
if the thermostat opens at 190 the temp will remain within 5 degrees of 190 either way, sounds to me the thermostat could be sticking closed??? 228 is WAY to hot.
The temperatures you are describing are completely normal for a 92, as they ran just like this straight from the factory as designed.
