My under hood lights dont work! Any suggestions
Re: My under hood lights dont work! Any suggestions (blk91)
Check and make sure the wires are plugged in. A lot of us will unplug them at shows and forget to hook them back up. On my '94 the plugs are in the nose (one on each side) about a foot from the wheel well were it starts curving towards the front.
Re: My under hood lights dont work! Any suggestions (R94 LT 1)
Re: My under hood lights dont work! Any suggestions (Glock'94)
Provided they are plugged in, check the connection at the bottom of the inner bumper. Lots of water gets in there and can corrode the connection.
Re: My under hood lights dont work! Any suggestions (Getaway)
I had the same problem. After a month of trying to figure out the problem I finally looked closely and they weren't plugged in. Duuuh! :crazy:
1 Post
There are some mercury switches....check those out. Also, maybe a previous owner might have install the after market kit that turns the lamps off when the hood is raised. Just a shot in the dark. Good luck. :flag
[Modified by GRX, 10:26 PM 9/21/2001]
