How hot it to hot for ATF? Whats your temp?
I just replaced my 4l60E transmission with one that is built stronger. The ATF in the old transmission at times was as high as 225 degrees. With the new one, I have seen it as high as 206 degrees.
Are these temps to high? What temps do you guys see?
Thanks for the replys guys. Good info in the link as well. I am tempted to take out my radatior and trans cooler and pressure wash the cooling fins on both of them. They are looking a little dirty, hopefully that will bring it down a few degrees.
1 Post
Somebody pointed out this also:
http://store.summitracing.com/partde...D14104&FROM=MG
I have one on order for my new 700R4.
St. Jude Donor '03 & '05
You have to clean it one fin at a time, unless someone else has a better idea.
And get a B&M stacked cooler. Mine runs 170 with 3.75 gears and 2800rpm Vigilante with an external cooler and a BeCool radiator which has a large cooler within the radiator.
