Need Some Cruise Control Help
Old 10-27-2006, 09:11 PM
JAKE
JAKE's Avatar
Default Need Some Cruise Control Help
I've got a thread running on the C4 General board - Cruise Control - trying to get help on sorting out why mine doesn't work.
Please take a look and give me any feedback on how to solve this. I don't want to duplicate it on this board.
Thanks,
Jake
Old 10-28-2006, 12:49 AM
93*Corvette
93*Corvette's Avatar
Thanks,
Jake
At least put in the link for us....
http://forums.corvetteforum.com/show....php?t=1475173
Old 10-28-2006, 09:17 PM
JAKE
JAKE's Avatar
I appreciate the advice and the assitance; should have thought of that myself.
Now, can someone please point me down the path to fix this Oh So Frustrating problem?
Jake
Old 10-29-2006, 01:44 AM
86PACER
86PACER's Avatar
Not related, but looking at your avatar, your front rims are on the wrong sides.
Old 10-29-2006, 11:23 AM
JAKE
JAKE's Avatar
"Oh, Grand Ma, what sharp little eyes you have", LOL
Those photos were taken by the previous owner when he was advertising the car for sale. I noticed it right off too and they were swapped before I took delivery.
BTW, the idiot tire changer damaged the two LTP sensors in the process, which the seller now has to replace at no cost to me.
Jake
Old 10-29-2006, 11:33 AM
Ruff Rider
Ruff Rider's Avatar
I'll be darn, they sure are.. Hey i could use a guy like you "one that pays attention to details" need a JOB....LOL 101st Air Borne
Old 10-29-2006, 11:41 AM
JAKE
JAKE's Avatar
See, it's one of the things I do to get attention; I've got this low self-esteem thing going on. LOL
Jake
Old 10-29-2006, 02:21 PM
obnoxus
obnoxus's Avatar
I know a big problem in these is the vaccum lines.
They either rub or dryrot, thats where I would start.
Old 10-30-2006, 01:40 AM
Skrud13
Skrud13's Avatar
During my engine rebuild (new head gaskets, water pump, etc) I found a vacuum hose by the distro that had a tiny hole in it. Replaced it and I got the cruise to work again.......now if I could just get it to hold speed. It drops about 1 mph every 10 seconds. Any ideas??
Old 10-30-2006, 08:36 AM
Bad Karma
Bad Karma's Avatar
Default I feel your pain
Mine doesn't work either. I found the vacuum line going to manifold was not connected, one of the T fitting melted. Somewhere behind the distibutor, so I have to dig in there and find the connection so I can fix it. Hopefully that will fix my problem.
For the dropping speed. I would check you vacuum lines, maybe there is another slow leave and you are not keeping enough vacuum to maintain speed?
Old 10-30-2006, 09:51 AM
HOWSER
HOWSER's Avatar
St. Jude Donor '09
Underneath the passenger side fuel rail cover there is a plastic "T" fitting that is prone to rot and breaking. It just needs to be replaced.
Very common on the LTx's.
Good luck.
Eric
Old 10-30-2006, 11:41 AM
juanway
juanway's Avatar
Default No cruise control
I found this plastic Vac. valve on drivers side near distributor had deteriated it is a vac valve that gets it vac near the fuel regulator the valve cost $7 dollars at the dealer and now my cruise works great.
Old 10-30-2006, 11:43 AM
Wildcat1
Wildcat1's Avatar
I had to readjust the sensor under the pedal after replacing my brake booster. That may be a good place to check.
To Need Some Cruise Control Help
Quick Reply: Need Some Cruise Control Help
