100k+ guys.. what is your oil pressure at idle when the oil gets around 200?
Mine is still around 10-12psi at idle.. the second I hit te gas it's up to 40 or higher.... you guys have similar readings?
Re: 100k+ guys.. what is your oil pressure at idle when the oil gets around 200? (Glock'94)
At idle, like 55. My oil almost never reaches 200, so I can't help you there........
Mine stays around 40 at idle when hot.. When I take off it usually gets up to 65 or 70. This is on my 84 it has around 150K on it.. The lowest I think I have seen mine when stopped in traffic in summer is around 36 or so.. :chevy
At idle, mine is near 80 psi cold, and goes to 30 - 40 psi when thoroughly warmed.
Tony
Tony
Re: 100k+ guys.. what is your oil pressure at idle when the oil gets around 200? (KLLRVET)
Arg.. well.. at least i'm within the GM recommended psi levels... 10psi for every 1000 rpm. As far as what I've read, the computer will shut off the fuel pump if the oil pressure gets too low for operation.
[Modified by Glock'94, 5:41 PM 9/18/2001]
both my LT1's exhibit same characterisitcs as yours glock.. the '93 has 130k miles on it and the '94 only has 2k miles on a new 383 build from the second LT1 that was in it ..
this with mobil1 10w-30.
Re: 100k+ guys.. what is your oil pressure at idle when the oil gets around 200? (tikiltd)
I have 150,000 on my 90. The oil pressure is about 45psi at idle. 10-12 seems very low.
And my '86 does not have the low oil pressure cutoff - I've run it out of oil and coasted home with an *indicated* 0psi...And re-started it and drove it in the garage...109K miles... :(
1 Post
On my L98, I was showing 24 psi at idle, and it would hop to about 40 psi under load.
After dissasembling the motor, there was NO way in hell i was making ANY oil pressure. My sensor was completely wrong, I now have a mechanical guage and I'm much more pleased with it.
BTW, my new motor is making 44 psi at idle. :eek:
Re: 100k+ guys.. what is your oil pressure at idle when the oil gets around 200? (NoWorries)
Bone stock L98 106K miles, shows about 50PSI at 600 RPM idle hot in Fl summer traffic.
The differences some see are the stock engines were build with super tight oil clearences because GM wanted to kill the "bearing noise" that almost all 350's had at idle. This gave a higher idle oil pressure and increased engine bearing life.
Racing the engine would definitely cause bearing wear that increased clearences and lowered idle oil pressure... I would say anything above 20 PSI at idle is acceptable. If it's 15 PSI at 600 RPM you have a main/cam bearing oil problem. I would start using heavier oil.
Re: 100k+ guys.. what is your oil pressure at idle when the oil gets around 200? (BBA)
[Modified by Glock'94, 9:09 PM 9/18/2001]
Glock - you and I have VERY similar setups and mileage (i have 124k) at idle I get about 20-25psi when the oil temp is @200 degrees.. what is important is that you have a minumin of 40psi at 3000 rpm.. that has been a standard GM number for some time.. you might consider running 10w-30 or 10w-40.. maybe the 5-15 is a bit extream..
100K on mine. 30psi at idle warmed up and 50psi above that. I wouldn't sweat the pressure reading now. My shop manual states a 6-8psi minimum pressure at idle. 30psi at anything above that is adequate.
Your engine will live until you rebuild (which from your previous posts, I believe isn't too far in the future).
Don't get hung up on "higher oil pressure is better". Gauges are notoriously inaccurate. Most *** engines have gone to just an oil light 'cause most won't register oil pressure on a gauge at idle (I know this from owning many a *** car with a gauge). I go by the 10psi per 100 horsepower rule. This would mean that 30psi on a stock LT-1 at full throttle would still give me warm, fuzzy feelings. Anything more is just wasted power at the oil pump.
Re: 100k+ guys.. what is your oil pressure at idle when the oil gets around 200? (BluByU)
Yours sounds a tad low but still within GM specs so don't worry about it too much. The lower pressure still indicates increased wear on the bearing surfaces, but the engine should continue to run for some time. :flag
130k on mine and 20w50 at idle @225* oil pressure is between 64-80psi
:flag
:flag
I have 135K on my engine and it is about 40 at idel and it goes to about 80 at high rpm but if the oil gets hot it will drop down about 10 on both ends, I think that I read on here that the LT1 does not have as much oil pressur as the older engines but it is plenty for them.
Jay
Jay
Mine with 68K and at 100 degrees outside @600RPM sometimes reads as low as 12 - 15 PSI. This is after I replaced the sensor with a generic one :( . Before that it would not go below 25PSI. I don't have much confidence in their accuracy.
Re: 100k+ guys.. what is your oil pressure at idle when the oil gets around 200? (85_togo)
:flag
:flag
Stock L98 with 98K miles. I get 36 hot at idle, 55 cruising. It gets arround 210-220*. I think 10 psi is way too low at idle. Sounds like a new pump may be in order. I would verify it is not the sending unit by hooking upo a mechainical gauge.
