Pulled my plugs. One is caked others are fine. Picture inside
Old 10-15-2006, 12:05 PM
crossfire7
crossfire7's Avatar
Default Pulled my plugs. One is caked others are fine. Picture inside
What the heck? My number 4 plug is caked with soot. The other 7 look fine. I need some help to fiqure this out. Thanks in advance.
Old 10-15-2006, 12:07 PM
Pete K
Pete K's Avatar
I would look for a bad plug wire or a bad injector first. It does not appear to be oil fouled.
Old 10-15-2006, 12:57 PM
bogus
bogus's Avatar
if that is a crossfire motor, I would be focusing on a bad wire.
Old 10-15-2006, 01:04 PM
crossfire7
crossfire7's Avatar
The motor is a 383 w/ TPIS Miniram.
Old 10-15-2006, 01:05 PM
bogus
bogus's Avatar
ok, do what pete said.
Old 10-15-2006, 01:17 PM
crossfire7
crossfire7's Avatar
Ok, will do. The plug wire I can test. How do I test the injector?
Old 10-15-2006, 01:54 PM
Pete K
Pete K's Avatar
You can ohm test them all and see if they are consistant with each other. If 1 or more read low, you will know they are electrically bad. If they are mechanically leaking, they are difficult to diagnose. The cheap way is to swap #4 injector with number 2 and see if that plug craps up.
Old 10-15-2006, 02:01 PM
crossfire7
crossfire7's Avatar
Thanks Pete and Bogus
Could the black plug have anything to do with the tune in the chip?
Old 10-15-2006, 02:20 PM
Pete K
Pete K's Avatar
Not likely. Our cars batch fire the injectors. They should all work equally(in theory anyhow)
Old 10-15-2006, 02:33 PM
crossfire7
crossfire7's Avatar
So am I save to assume that there isn't anything wrong mechanically with the motor/valve train?
Old 10-15-2006, 02:36 PM
Pete K
Pete K's Avatar
You "may" have a guide or seal problem, but don't worry yet. If the cylinder is passing a small amount of oil, it could crap up the plug. Small chevy's usually dirty up #7 or #8 before the other plugs(regarding oil pumping).
Your pic does look like a secondary ignition or fuel injector problem.
Old 10-15-2006, 02:49 PM
crossfire7
crossfire7's Avatar
Great info Thank you!
Old 10-15-2006, 03:00 PM
Pete K
Pete K's Avatar
I noticed that you edited the origion post to include a better pic. The 1 pic does seem to show oil fouling. However, that will happen after a plug carbons up and fouls. Like I mentioned, no panicking yet. Eliminate the other variables before upsetting yourself.
Old 10-15-2006, 03:37 PM
Randy93
Randy93's Avatar
St. Jude Donor '06
It also apprears there is oil on the threads of all the plugs. I think the one is oil fouled, my number 7 looked the same last week when I changed mine.
To Pulled my plugs. One is caked others are fine. Picture inside
Quick Reply: Pulled my plugs. One is caked others are fine. Picture inside
