Air pump removal
Air pump removal
I have been looking at my new toy and have noticed the air pump isn't hooked up completely. The connectors for the exhaust manifolds are open. Air just blows right out the connectors insted of going to the headers. Only place it is connected is in the back of the intake. Since I doubt that a lot of air is actually making it into the intake, would it hurt to just remove the whole mess?
Not a big deal since I have already passed e-check and it even passed the visual
It's a 95. I don't know about not passing visual if I remove it completely. It passed and there were open connections on both headers and the air line.
The air check valves or a plug should still be in the headers, otherwise you have an exhaust leak. That's a bad thing. You should remove the air system and reprogram the computer to delete it or you will get codes. The right side air pipe is also used as the EGR pipe. That is why it hooks into the rear of the intake manifold. The EGR system also hooks into the computer and should be left operational. It actually plays an important part in controlling heat and emissions unless you have a bigger cam in which case you can block off the manifold and delete the EGR from the computer also. As a Federal emissions control, these two devices cannot be legally removed in any state even though newer cars don't even have them any more. I'm guessing you either lucked out on the visual or the tech just didn't care.
Hope this helps.
Hope this helps.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I found it much easier to reinstall all that stuff if you hack the tubes up into a few pieces. Then just shove them under the accessories so you can't see the cut ends, and use the little hoses to hold them in place. I can do this without even removing anything. Installing them correctly is much harder.
Hope this helps.
Hope this helps.
The rest came off afterwards.
This will come in handy with the long center piece specially. I won't have to unbolt the AC braket and remove the air pump anymore and try to fish it out from under the fuel lines. Damn good idea.
Best wishes from Germany
Eike
I'm removing (& plugging) my AIR system on my '85 this week. I found that it was the source of that hissing noise @ 2500 under load. Until I can afford the pulley kit, I plan on leaving the pump where it is. There are no emissions or inspections in MN, but I'm keeping the parts anyhow.
I found this problem by elimination.
1. Remove brake booseter line and test drive. Still there. Braking sucked. Wish someone had told me first.
2. Got an unlit propane torch and searched for leaks. Found none after 10 minutes. Got high from fumes. Happy I don't smoke. Openned garage door.
3. Removed tube from AIR pump and went on a test drive. NO NOISE! Decided I don't want to mess with finding the leak, so the system is comoing out! Took a but-ton of pics first, in case I need to reinstall.
Sorry to bring this back up..
I just put the air pump delete kit on and am removing the rest of the junk... the diverter valve (I think) has a tube that goes down to the crank case (I think?)... do you just cap that off?
I assume also that the hose that goes from the diverter to the plenum (which has a T to the FPR) gets pulled and then a small hose is made from the plenum to the FPR, right?
On a side note, I found a perfect cap for the manifolds!! Went to HomeDepot and the 1/2" pipe cap found in the plumbing section fits absolutely PERFECT!
