'86 L98 IAC Adjustment Help Please
Here's the procedure..Insert a clip, or jump the A&B terminal in the ALDL...turn the key to the ON, but don't start...the fan will probably turn on..don't worry.Wait about 30 seconds, then disconnect the IAC. The 30 seconds will allow the pintle to fully extend giving the ECM a new base zero to calculate and adjust IAC counts. Turn the ignition off, IAC still disconnected, remove the jumper from A&B.Start the engine and let it warm up,it may be a little difficult to keep it running, but should idle nicely after it warms up...140* should be fine. Reconnect the IAC and drive it, it's supposed to reset it after 30-35 mile at 30/40 MPH.
No need to worry about the EST while setting the IAC. It's always a good idea to check the TPS, it's simple and also one of our most important sensors, this is done with the engine off..key on.
Originally Posted by Da Mail Man
.....any involvement of the est wire with this proceedure?....does not the tps need to be adjusted also?...i have read similar posts and 1 says to disconect the est while setting idle, another says not...etc?..
RACE ON!!!
Originally Posted by CFI-EFI
There is no idle adjustment on these cars. The idle speed is burned into the chip. It appears you are confusing rick lambert's explanation of re-acclimating the IAC after servicing or replacement, with the minimum air adjustment procedure. Disconnecting the EST is only necessary for setting the timing, and for the minimum air adjustment for some, specified years, consult YOUR FSM. If the minimum air adjustment isn't changed, then the TPS adjustment isn't affected. However, as rick lambert says, "It's always a good idea to check the TPS".
RACE ON!!!
RACE ON!!!
OK. But the rest, after the first two sentences, still applys.
RACE ON!!!
Thanks for all the help guys. I guess the tech tip is a little misleading. The tip instructs you to extend the pintel using a jumper with the IAC connected then remove jumper disconnect IAC and set idle to 400 in drive after warm up. I couldn't get the idle below 1,000 with the IAC disconnected. I'm going to reset the IAC per Rick's method tomorrow and post my results. Thanks again
1. Warm up the engine.
2. With engine off, key off, jump terminals "A" and "B" on your ALDL.
3. Switch the key to "On". So not start the engine.
4. After 30 seconds, key still "On" and the jumper still in place, unplug the wire connector from the IAC valve.
5. Turn the ignition to "Off" and remove the jumper wire on the ALDL.
6. Check YOUR FSM to see if your car should have the EST disconnected.
7. Start your engine and adjust the throttle stop screw, if necessary, to obtain the specified or desired (400-450 rpm) minimum air, engine speed. This is NOT the idle speed adjustment, but it IS the same operation as if it were.
8. Shut off the engine, and reconnect the IAC wiring connector.
9. Switch the key to "On", engine "Off", and adjust the TPS.
10. Re-acclimate the IAC as this whole thread has described. MY FSM simply says to drive the warmed up car at a speed of over 35 - 40 mph.
Your post, quoted above, had some of the operations out of sequence which would explain why you couldn't get the engine slowed enough down to make the adjustment. With the ignition on and the ALDL jumped, the IAC pintle extends and closes off the IAC passages. THEN you disconnect the IAC, with the pintle extended before you remove the jumper. Otherwise the pintle retracts, and the engine will have more than just the throttle blades as a source of air.
RACE ON!!!
Originally Posted by davemack
Definitely check TPS voltage. If it's badly out of adjustment (high voltage), you can idle at 1200 rpm without the min idle set screw even touching.
If that doesn't do it, check throttle plates to be sure they're fully closed when car is off. Any dirt build up that causes even a small gap can result in a high idle.
If that fails, join the club. I've been chasing an irregular idle condition all year...
RACE ON!!!
Originally Posted by redrose
dunno what anybody else is lookin at, but my 86 FSM, page 6E3-C2-11 sez
! IMPORTANT
Disconnect the distributor set-timing connector.
! IMPORTANT
RACE ON!!!
You are 100% correct CFI-EFI, it's alway important to check the FSMs...year specific. Even the 86s have minor differences from the 87s, and I suppose the 85s do too, obviously the 84 CFI has major differences.
You got THAT right. According to the FSM, you have to synchronize (balance) the TBs, with a manometer, before you make the minimum air adjustment. Can I borrow your manometer?
RACE ON!!!
RACE ON!!!
