Christine is gonna kill me one day... stalled out while crossing intersection... help
#61
Morgan, maybe this quote from the FSM will help you understand.
" As a backup system to the fuel pump relay, the fuel pump can also be turned "ON" by the oil pressure switch". a little more-" If the fuel pump relay fails, the oil pressure switch will close and run the fuel pump.
No where in the FSM does it state the oil pressure switch will kill the supply of fuel in the event oil pressure is less than 4 pounds.
Maybe time to look at codes 44 and 45 simply because of what the scann showed.
#62
Originally Posted by Da Mail Man
......woah!......i agreed in part........i am easing out of this for a bit.
Originally Posted by morgan_kane
First - Relay on provides power to pump when cranking. After that ecm opens the relay, and current to pump goes through oil pressure switch. THERE IS NO TWO PARALLEL SOURCES. This is done to protect engine against oil pressure fail.
Originally Posted by CFI-EFI
Get your FSM out and look up what proves your position and me wrong. I think you will learn how it REALLY works.
RACE ON!!!
RACE ON!!!
My FSM says exactly:
Fuel pump control (During start only)
In ecm connector, where it controls fuel pump relay. I believe this is true. I think this says clearly that ecm energizes relay only during startup.
Also, i don't understand, why there should be two parallel connections? Why is other connection made through oil pressure switch, if it does not protect anything? Can you explain that?
Originally Posted by kopbet89c4
Are they the same part? I just see one part...
yes, sender and switch are inside same unit.
First, there is no connection from either the oil pressure sender, or the oil pressure switch, to the ECM. The oil pressure sender connects to the gauge as it would in a non-computer car. The fuel pressure switch feeds 12 volts through circuit# 458 directly to circuit# 120 to the fuel pump, through the fuel pump fuse.
Yes, i never argued that. i fact i said, that sender sends information to gauges, didn't mention ecm.
I don't want to argue things, only provide information for my FSM, and what i think is correct.
RACE ON!!!
#63
St. Jude Donor '10-'11-'12-'13
Originally Posted by ninetyfivevette
I believe MAF is only used in closed loop, so that would make sense. That would also say your MAP sensor is good too.
#64
#65
Your FSM says all three of those lines? Your FSM believes "this is true"? At best, I think you have taken something out of context. If you keep reading you will find what I have written.
http://finnshark.com/gallery/files/3...p_original.jpg
Tell me where i was wrong?
YOU not understanding something, doesn't make it untrue. Yes, I "Can you explain that". The purpose of the oil pressure switch is to act as a back up, in case of fuel pump relay failure. You will find THAT in your FSM, also.
1989 was the first time since early 1984 that the gauge sender and the oil pump switch were in the same housing. You can tell they are one in the same, by the three wire connector. The sender uses one wire and the switch uses two.
http://finnshark.com/gallery/files/3...h_original.jpg
It seems to me that they share same housing. Maybe they can be separated, but i just answered to kopbet's question.
Are you going to publish your own FSM?
http://finnshark.com/gallery/files/3...s_original.jpg
It is original GM manual.
#66
Maybe different years have different protocols?
EDIT:
I checked my FSM (not electrical supplement) and it states backup version too. So you both right. There is some lack in the electric supplement manual, because it says that relay is on only when starting.
Still, it is hard to understand, why backup circuit is made through oil switch? Why just another relay? It just feels logical that it was made to protect engine. Now there is no protection, in spite of oil pressure switch.
#67
Here is scanned picture from FSM schematic:
Why fuel pump needs backup? Why not ignition system, alternator or even airbags have backup, if fuel pump needs it?
Hmm.. my -87 manual has this picture:
Nop, this is where those pictures are taken from:
RACE ON!!!
#68
You were going to prove where *I* was wrong, remember?
Your schematic is either 344 pixels wide, too small to read, or 2294 pixels, about 4 pages wide, where one can't see enough of it, without extensive panning and scanning, to make sense of it.
They don't have to be separated. They already are. As it is clearly shown in your illustration, the oil pressure switch, with it's two wire connector, screws into the pipe tee from the top. The oil pressure switch, with it's single wire connector screws in from the 4:00 o'clock position. Your illustration proves my point that from part year 1984, and up to near the '90s, they were two separate devices. Luckily for you, they changed back to a single unit in 1989, makomg your answer correct, but you didn't know that when you said they were one unit. Your illustration proves that.
citing (kopbet89c4) "So where is my oil pressure sensor and oil pressure switch? Are they in the same vicinity or are they way apart in different areas of the car?"
I NEVER SAID THEY ARE ONE UNIT, I ONLY STATED THAT THEY ARE NEXT TO EACH OTHER.
Your source of info appears to be impeccable. Now all you have to do is learn to interpret it properly.
How in your opinion i should interpret it??
#69
I would be concerned with the BLM of 108 from the original post.
This means that you are very rich and at the limit of the ecm's ability to provide rich mixture compensation while in closed loop. From this infomation, it can be inferred that you're also running very rich in open loop at this rpm/load condition.
Things that may cause you to be very rich in open loop:
Too much fuel pressure
injectors too big (if > 23 #)
leaking injectors
tune open loop a/f increase vs temp, open loop a/f increase vs load, startup fuel vs temp, injector constant, bpw vs load, MAF calibration, etc.
MAF calibration (Over estimated airflow from MAF skews the load calculation and resultant fueling)
Low vacuum -> increases fuel pressure
Not enough spark advance -> contributes to low vacuum and also tends to raise the load due to increased airflow requirement.
Things that you can do to influence the open loop mixture:
Fuel pressure: reduce if you have an AFPR
Injectors: replace if too big, or leaking.
MAF calibration: reduce output if you have an adjustable MAF, or chip tuning capability.
Tune: if you can work with a tuner or tune your own chips, lots of possibilites here (injector constant, MAF tables, Target AFR, etc.)
Correct ignition timing
Adjusting fuel pressure should help to put your blms in the ballpark try to target 128. I would try this first.
If the MAF is acting flaky and erratic, it can be disconnected forcing limp home mode where the airflow is calculated instead from the tps sensor (no guarantee that the resulting signal is a good fit to your car's appetite for air). If you go this route, you will still likely need to adjust fuel pressure to improve the resulting mixture.
leaking injectors
#70
Let's think about this for a second.
-Fuel supply at time of stall...........x (fuel pump, relay & oil switch)
-Stable fuel pressure (44 psi) at time of stall......x (FPR)
-Injector pulse at time of stall..... existent, but correct pulse duration??
We should investigate spark... or less likely, the injector control system.
kopbet89c4, morgan_kane, CFI-EFI and others... do you disagree?
#71
Could there be a small air bubble in the fuel line while starting up??? Is it possible that the air bubble can form once the car cools down? I think that could cause possible stalling on part throttle while warming her up again...
Today, I warmed her up to about 180 degrees before I started driving. I felt the roughness in the idle about 5 minutes before driving. That rough idle lasted for about 1 minute meaning if I pressed the pedal down while it was idling that way, it would stall out...
I can see how the car would idle roughly when that happens... temporary lean condition...
Funny how when this stalling happens, there are no codes.
If this is indeed an air bubble forming in the fuel line during cool down, what can be done to prevent it???
If I have 44 psi of fuel pressure when the car stalls, could that "air bubble at 44 psi" be fooling the fuel pressure gauge as well?
Remember, the car will literally drive forever once warmed up.
#72
What you agreed to "......i agreed in part........" was:
Which is totally false and wrong. Ease into your FSM for a while and LEARN how your car works.
I didn't say that you did. I had lumped a response to both you and jcsr72, who said, "MAYBE his digital dash gauge shows good oil pressure from the oil pressure "sensor", but the circuit between the ECM and the oil pressure "switch" may be faulty.". It appears you agree, there is no such circuit.
Are you going to publish your own FSM? You may have a problem with the "F" part of your FSM, as the factory has already designated an author/printer. Even the old, imperfect, FSM has plenty we can all learn from. Better to study IT, rather than add "what i think is correct", because, in some cases, as demonstrated in this thread, you are wrong.
RACE ON!!!
RACE ON!!!
#73
RACE ON!!!
#74
Time to get back to helping this guy. I can't go with air bubbles in the line. Just a few thoughts, what were the IAC counts when you were scanning? And have you checked the voltage at the TPS? I'm leaning toward eliminating any fuel delivery problems with the fuel pressure you have, and the fact you're running rich. You may even want to check the air duct and look for anything that could introduce more air, any leaks.BTW, I'd check those plugs.
#75
..........****i thought i eased out of this discussion for a bit?
RACE ON
#76
All Good Thoughts.
#77
They don't have to be separated. They already are. As it is clearly shown in your illustration, the oil pressure switch, with it's two wire connector, screws into the pipe tee from the top. The oil pressure switch, with it's single wire connector screws in from the 4:00 o'clock position. Your illustration proves my point that from part year 1984, and up to near the '90s, they were two separate devices. Luckily for you, they changed back to a single unit in 1989, making your answer correct, but you didn't know that when you said they were one unit. Your illustration proves that.
RACE ON!!!
#78
But is there a possibility that the resistance in the TPS has skewwed over time? I checked the boot, as well as the connection to the TB. My traffic cone boot is completely free of any air leaks.
So I set the fuel pressure to 36 psi before a cold start. Same problem... stalls in roughly 2 minutes; the same amount of time as it would stall even if the fuel pressure was at 44 psi.
At both fuel pressures, the BLM was 128 on a cold start, and at both times it stalled.
Once warmed up in closed loop mode, the BLMs seem to get lower and today they were between 108-120 when idling. On part throttle, the BLM was 124 and WOT it was 128. Any yes, since it was fully warmed up with the coolant temps at the 170s to 190s, it ran perfect, not a skip, miss, sag, or stumble.
The car is as unreliable as a beat up 1989 Ford Escort a few minutes after start up. Needless to say, it acts like a POS. Once its fully warmed up, its acts exactly how a Corvette should be. Fast and throttle happy!
I compare it to a kid that doesn't like getting up for school in the morning. But once she's up, she's ready to rumble and run with the big boys!
#79
Hmm, i thought closed loop happend pretty much after about 2mins of engine running time, in which is enough time for proper temp etc for it to go into closed loop. I don't think open/closed loops is your problem. Have you checked your temp sensor for the ECM? put it in a bowl of boiling water with themometer and checked resistance at various temps. Could be that when sensor gets to around the 115 mark it gives an incorrect reading and ECM thinks water is cold and so richens the fuel way up. Just a thought, good luck
#80
The moment it stalled, the laptop, aka the scanner displayed 117 degrees. Another time it stalled it read 119 degrees. I can't see how that sensor would be bad if I had valid readings from the scan. And if there was an intermittent open in the sensor, I'd be seeing -30 something degrees for the coolant temp and get a code. If there was an intermittent short in the sensor, the coolant gauge would read like over 300 degrees for the coolant temp and also get a code.
