Brake Flush w/ATE Super Blue
Old 08-12-2006, 08:18 PM
RobWilson
Support Corvetteforum!
RobWilson's Avatar
Default Brake Flush w/ATE Super Blue
Are any of you guys running ATE Super Blue brake fluid? I'm running it in my C5 because I do some occasional high speed open road races with it (Big Bend Open Road Race). I have a liter of unopened Super Blue that I'm thinking of using for my CE vert I bought yesterday. The car is 11 years old and still has the original brake fluid. Is 1 liter enought to flush the brakes in a '96? Thanks!
Old 08-12-2006, 08:25 PM
Corvette Kid
Large Impressive Member
Corvette Kid's Avatar
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That should be more than adequate for flushing any car. Kudos to you for knowing what an important PM measure brake fluid flushing is, for any vehicle!
Old 08-12-2006, 08:32 PM
RobWilson
RobWilson's Avatar
Thanks!
Old 08-12-2006, 09:22 PM
Louis Bartay
Louis Bartay's Avatar
We just replaced my J-55 calipers with GS calipers and new Russell stainless lines and it took a almost a whole 32 oz bottle of DOT3 Synthetic 284wet and 470 degree dry boiling point for ABS. make sure you use Only DOT 3 for your 96.
Old 08-12-2006, 10:36 PM
byedan
byedan's Avatar
you can also use d.o.t 4 just no silicone brake fluid, you can also use synthetic brake fluid also
Old 08-13-2006, 12:35 PM
C4DC
C4DC's Avatar
St. Jude Donor '06
1 liter will leave you with a little left over.
To Brake Flush w/ATE Super Blue
Quick Reply: Brake Flush w/ATE Super Blue
