Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-10-2006, 09:14 PM   #1
86conv
CF Member
86conv's Avatar
Send a message via MSN to 86conv
Default 86 vette with a code 12 and 34
I have seen some of the threads here and some indicate it to be a Map sensor or a Maf sensor. Can anyone tell me what it is and the cost. It seems the Maf is expensive and the Map significantly cheaper.
Car is cutting out after it heats up. Took the codes and got a 12 (nothing) and a 34.
86conv is offline   Reply With Quote
Old 07-10-2006, 09:23 PM   #2
86Pacecar
CF Senior Member
86Pacecar's Avatar
A code 34 is a MAF sensor signal voltage low.
Code 34 indicates:
ECM has seen low air flow (low voltage) for one second when:
Engine is first started
OR
RPM is above 600
TPS above 6%, the engine has to be running at about 2000 RPM in neutral.
You really need to get a Helms Manual to follow the troubleshooting charts to repair this otherwise it's just throwing parts at it.
86Pacecar is offline   Reply With Quote
Old 07-10-2006, 09:40 PM   #3
86PACER
CF Senior Member
86PACER's Avatar
Code 12 is not a trouble code. It flashed 3 times at the begining and end of the code reading process. It's there to tell you when the test starts and ends. The code(s) you see in between are your troble codes. Code 34 was in between the code 12 flashes, so that is your trouble code.
Code 34 is indeed the MAF sensor circuit. It's the black plastic thing between your throttle body and air filter attached to the accordian air duct. It has a connector on the bottom of it.
Unplug the MAF and start the car.
If the problem goes away with it unplugged, and returns when you plug it back on, it's the MAF sensor that's bad, and it's expensive. Do that first then come back and tell us what you found.
If got the problem with it unplugged, there are other things that need cheking (see link below), but do that test first and them come back.
86PACER is offline   Reply With Quote
Old 07-10-2006, 09:55 PM   #4
86PACER
CF Senior Member
86PACER's Avatar
Here. Member Agent 86 did this for you.
http://members.shaw.ca/corvette86/Code%2034.pdf
Old 07-10-2006, 10:44 PM   #5
RRT vette
CF Senior Member
RRT vette's Avatar
Follow the pdf from Agent86 or the pm sent, for you answer.
All other suggestions are correct.
RRT vette is offline   Reply With Quote
Old 07-11-2006, 04:20 PM   #6
86conv
CF Member
86conv's Avatar
Car does the same thing when unplugged ......cars still stalls when hot
Old 07-11-2006, 04:22 PM   #7
86conv
CF Member
86conv's Avatar
Quote:
Also checked injectors and got a reading of 17.2..they seem fine
Old 07-11-2006, 05:09 PM   #8
86PACER
CF Senior Member
86PACER's Avatar
First fix code 34 before you start getting into the fuel system. See link above.
BTW, ohming the injectors won't tell you anything about leaks or bad spray patterns.
Reload this Page 86 vette with a code 12 and 34
Tags
34, 86, code, computer, corvette, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
