Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-30-2006, 02:21 AM   #1
lcvette
CF Senior Member
lcvette's Avatar
Send a message via AIM to lcvette
Default 96 LT4 single T74gts Turbo Dyno vid and graph
Hey all,
I have been hiding out over in the FI section for the last year now, but have recently finished up a very long and elaborate project of turbocharging my 96 LT4 collectors edition. and below are the initial dyno pulls fort he startof tuning before noticing I had only one of the twin intank pumps running and the other was defective. so only two runs, and there will be more coming as tuning progresses after installing another pump. hope you enjoy!
for any interested, the setup is below.
Chris
NOTE: I have found that you need to hit the switch to microsoft windows media player for the sound to work on a few computers. if you did not hear anything that should fix the glitch!
Chris
http://videos.streetfire.net/video/w...def2efada8.htm
ENGINE
-355 forged bottom 8.7 : 1 CR shortblock
-Trickflow heads (unported) gonna wait before I go that route
-Stock LT4 camshaft - also gonna wait on this
-crane gold rockers/.083 extreme pushrods/ comp R lifters
-dual roller billet timing set
-K-motion double springs and Ti retainers, 10* locks
-ported LT1 intake manifold
-58mm throttle body
-Meziere electric waterpump
FUEL SYSTEM
-Twin intank walbro 255lph pumps
-(-10 AN) fuel line to barry grant filter to aeromotive regulator
-custom fabbed fuel rails
-83 lb/hr low Z injectors
-(-8 AN) return line
-racetronix wiring harness kits for both pumps wired independantly
ENGINE MANAGEMENT
-Accel DFI Gen 7 w/ dual synch distributor (opti delete)
-Accel DFI wide band O2
-Accel DFI knock module
-Fast track performance harness to retain ALL dash functionality
TURBO SYSTEM
-T 74 GTS turbocharger
-50mm Wastegate
-50mm Blow Off Valve
-Greddy Profec Spec 2 boost controller
-12" x 27" x 4" thick FMIC
-all 3" cold side aluminum plumbing
-custom self fabbed hot side parts all stainless steel
IGNITION
-MSD 6A
-MSD 8.5 super conductor wires
-MSD Blaster Coil
-NGK TR6 plugs
lcvette is offline   Reply With Quote
Old 05-30-2006, 02:38 AM   #2
Trizney
CF Senior Member
Trizney's Avatar
Send a message via AIM to Trizney Send a message via MSN to Trizney
Kick ass man!!
Congrats
What's up with all the smoke from the tail pipes when you let off the throttle?
Trizney is offline   Reply With Quote
Old 05-30-2006, 11:02 AM   #3
LTjuan
Junior Member
Quote:
Originally Posted by Trizney
Kick ass man!!
Congrats
I would agree that that is kick azz.
As far as the white smoke my guess is: When he let off the gas the waste gate opened up, dumped the boost and a bunch of unburnt fuel went into the cats/mufflers. I would guess that if it has cats it wont for long.
I would love to see pictures of the engine and how you ran the plumbing.
John
LTjuan is offline   Reply With Quote
Old 05-30-2006, 11:25 AM   #4
LT4POWR
CF Senior Member
LT4POWR's Avatar
Good to finally see some #s. Get that sucker dialed in and have fun w/ it!!!
__________________
1996 LT4 Corvette
416rwhp/375rwtq (SAE) - NA Stock Bottom End
2004 Cadillac CTS-V
Stock (for now) LS6
LT4POWR is offline   Reply With Quote
Old 05-30-2006, 12:07 PM   #5
C4DC
CF Senior Member
St. Jude Donor '06
1996 Chevrolet Corvette
C4DC's Avatar
Looks like a monster! Love that spool sound.
C4DC is offline   Reply With Quote
Old 05-30-2006, 03:14 PM   #6
all4c4lt4
CF Senior Member
all4c4lt4's Avatar
That is sweet.
all4c4lt4 is offline   Reply With Quote
Old 05-30-2006, 08:04 PM   #7
lcvette
CF Senior Member
lcvette's Avatar
thanks guys... I have found that you need to hit the switch to microsoft media player for the sound to work on a few computers. if you did not hear anything that should fix the glitch!
Chris
Old 05-30-2006, 08:51 PM   #8
jonecap
CF Senior Member
jonecap's Avatar
Let's see a video clip of it on the street. I bet you it's bad a$$. I just bought a '96 CE LT4 myself.
jonecap is offline   Reply With Quote
Old 05-30-2006, 08:51 PM   #9
jonecap
CF Senior Member
jonecap's Avatar
Old 05-30-2006, 09:05 PM   #10
NassauCoupe99
CF Senior Member
St. Jude Donor '07-'08-'09
NassauCoupe99's Avatar
Send a message via AIM to NassauCoupe99
Man that looks fun!! i love the sound of the turbo spooling up and that blow off valve. nice work, and of course, We need pics!
NassauCoupe99 is offline   Reply With Quote
Old 05-31-2006, 03:48 PM   #11
lcvette
CF Senior Member
lcvette's Avatar
thanks guys,
I appreciate it! I am working on another brief video that I will post in this thread this evening which will have some shots of the engine bay and turbo setup. thanks again for looking in!
Chris
Old 05-31-2006, 05:03 PM   #12
DieL
CF Senior Member
DieL's Avatar
Chris,
that is an awesome setup! It's nice to see someone else with no opticrap I went a similar route but definitely wont be making that kind of power !!
That is one badass ride !!!!!!!!
* Out of curiousity, what 58mm TB are you using and did you check for full throttle ?
DieL is offline   Reply With Quote
Old 05-31-2006, 07:37 PM   #13
lcvette
CF Senior Member
lcvette's Avatar
I am using a Holley 58, and yes checked for full throttle and am not getting it.. it has the bell crank for the 95 LT1 on there which has the wire end much closer to the shaft pivot point and is only allowing me about 62% throttle opening according to the TPS which I calibrated from idle position to WOT by hand to get a full sweep. I just recently swapped TB's with my dad's 96 Holley 58mm unit and it definately woke the car up over 4500 RPM.. gained another 600 rpm worth of pull seems like and added some punch when boost comes on. now if I can get Racetronix to get in touch with me and figure a solution out with replacing or repairing a bad pump I will be able to dial the boost up with a safe air fuel ratio and really start working on getting the timing tweaked and advanced to reap full benefit of this motor. my goals as of right now are to get her to 650-700 at the wheels without changing cams.. I think with all the little issues I have right now fixed and pushing closer to 22-23 pounds of boost with a great tune it is attainable after all another 9 pounds of boost is quite a bit.. then when that gets boring I will swap to a more aggressive cam and do some porting on the heads and intake manifold. then the new goal may require a slightly larger compressor wheel.. something like a 81 or 85mm. but that is a ways off.. gotta finish the first phase before I go nuts with it.
Chris
Old 05-31-2006, 07:51 PM   #14
DieL
CF Senior Member
DieL's Avatar
Chris,
I would have to guess if you were on the dyno with 62% throttle theres much more in it as it is. If i might add that 700 at the wheels with a stock idle, stock heads is insane. I honestly think changine heads and cam would be a waste of time since you are at the point of having too much for the street already ! Where did you decide to mount the dfi unit ? also im curious to know what you did for a coil setup. I removed my ecm so my dfi sits in its place. I opted to use the stock coil location and run a coil wire but dont like running a 30" coil wire so i might install a coil by the distributor on the firewall. Also curious about your fuel lines, I had to go with an fitting on the rear and we used an external regulator mounted by the coolant reservoir. pics !!
Old 05-31-2006, 07:54 PM   #15
DieL
CF Senior Member
DieL's Avatar
ALmost forgot to ask.. how was yur coolant temps during the dyno pulls? Im using a mezziere as well and was curious to see if it can cope with the extra heat from being under load for extended periods.
Old 05-31-2006, 11:36 PM   #16
lcvette
CF Senior Member
lcvette's Avatar
here are some pictures.. took about 10 minutes to fab up the bracket and there is an existing stud in the firewall to mount it too. so far no issues whatsoever and uses a much shorter coil wire and the stock wiring from the passenger side fuel rail cover is easy to direct over to it.
as for the fuel system here is a shot of it...
I am using -10 feed to the regulator then split after the regulator to twin -8an lines to the back of the rails.
I am also running twin intank walbro GSS340M pumps.. the fuel system should be good for about 1000rwhp.. but my 83lb/hr injectors are estimated to about 850rwhp or so before they are approaching their duty cycle limits.. I plan on eventually needing 96'ers..
have any pics of your setup?
Chris
Old 06-01-2006, 06:22 PM   #17
DieL
CF Senior Member
DieL's Avatar
Chris that looks awesome! I like your coil setup on the firewall. i had concerns with my coil being in the stock location and having a 30" wire but msd assured me anything less than 36" would be fine. i think I'll switch it there when i get a chance. I might be heading up to the shoppe tonight, If not tonight for sure tommorow. I'll get some pics up asap. I havn't taken many pics yet because i have all the rail covers and other small detail things at home and i was waiting to bring the car home to clean it all up and then put everything together.
Old 06-01-2006, 11:53 PM   #18
lcvette
CF Senior Member
lcvette's Avatar
Diel,
yeah I was pretty much space limited on where I could mount my coil so when I discovered it would work there it was a no brainer for my setup.. looking forward to seeing the pics man!
here is another video from another angle with some music made by another forum member..
http://videos.streetfire.net/video/7...4277167da6.htm
Chris
Reload this Page 96 LT4 single T74gts Turbo Dyno vid and graph
Tags
1996, charger, corvette, lt4, tuning, turbo, turbocharger
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
