Can't stop my coolant leak
My 1991 383 stroker with ATI procharger running 8 lbs of boost keeps blowing coolant out the thermostat housing under heavy load. First noticed it on a dynopull, going over 4K under load made coolant shoot out the thermostat housing. In normal driving, even over long distances, everything stays dry, same thing if you just rev it in neutral.
Replaced the gasket today, careful to scrape off all the old gasket material and adhesive and cleaned up with solvent - went out for a drive, came back, still got coolant spraying around in the same vicinity it was before. I'm assuming it's still coming out of the thermostat housing since it's wet in the same areas it was wet before, but I can't be 100% certain this time since I didn't have the advantage of seeing it on the dyno. In normal driving, even over long distances everything stays dry, it's only when I'm really getting on it. Any ideas?
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Did you run a fine file over the thermostat housing surface to see if it was true? I've seen plenty of these get distorted.
Originally Posted by comp
boost pressure into the coolant
Actually though, it wouldn't be hard to rig a temporary pressure gauge into the cooling system and see what kind of pressure it's building during hard runs.
Do you have a high flow thermostat? Is your pump bypass plugged?
Hmmm, hand't thought about the boost pressure getting into the coolant, that makes sense though.
I did run a file over the housing before reinstalling gasket.
Can I simply disconnect the hose from the ProCharger without any problems? Will it run like crap if the F.A.S.T. engine management is expecting boost and it isn't there? Can any damage result to the ProCharger if I eliminate the backpressure by disconnecting the hose?
Received 3,043 Likes
St. Jude Donor '05
Whose water pump are you running?
i'd try checking pressure's,,, rad. cap first
Ok, just found this kit on Summit Racing - http://store.summitracing.com/egnsea...5&autoview=sku
This must be what you were referring to. Can you leave this in the car though while you drive it?
Also, I was never aware there were "high flow" thermostats. But it does seem that pretty much all of them are, so since it's a 180 degree aftermarket thermostat, I guess I would say "yes" it is? Do you think that could do it? If it's feasible, that's a cheap and easy thing to try.
I must be missing something, how would I go about this? If it is boost pressurizing the coolant, and it leaks back out from the themostat housing, how would I test pressure at the rad cap? Is there such a thing as a rad. cap with a pressure gage that reads the maximum pressure, not the current pressure?
Well, got the kit from Summit and pressurized the system up to 25 lbs before it started leaking from a hose fitting right next to the cap, but nothing from the thermostat housing. Then I let the pressure off and started the car. It built up to 9 lbs. at idle before I shut it off. The coolant pressure had been steady at 180 since about 5 or 6 lbs. So it does appear to be a boost leak. Head gasket seem like the most logical place to start?
In thinking about this further, a head gasket leak doesn't make sense. My procharger only provides boost to 8 psi. The coolant pressure should reach 15 psi (right?). If there was a head gasket leak, the procharger wouldn't pressurize the coolant, coolant would leak into the cylinders since the coolant pressure is higher than the boost pressure. Rethinking it, maybe the thermostat housing is warped and heating it up to 180 or warmer causes it to leak. So, I heated the car up with the pressure tester hooked up, then shut it down and manually pumped it up to 25 psi again. This time it leaked from the thermostat housing where it didn't when it was cold. So how would you go about figuring out if the problem was with the upper thermostat housing or the base and how would you correct it? Particularly how would you correct it if it was the base?
