MSD OPTI. Any news yet???
1 Post
St. Jude Contributor
Originally Posted by Vette Threat
Corvette Central in their latest catalog has both styles. $519.OO each
I'll be grabbing one soon to go with my new engine and I'll post a review at that time.
I guess if it lasts several years, it's worth it...
Originally Posted by edsalinas
Summit lists the early style for $499.00.
1 Post
Originally Posted by RacerX70CC
I got that beat.... just a matter of when they hit the door.
So tell us,
how much $$ can you sell me an early style for? I'll be tearing the front of the LT1 apart in the next few days, so I'll be looking to pick one up soon... PM me with the info bro.
What is the actual improvement in construction. Is it going to prevent the problems that the opti is currently having. Is it sealed better, will it prevent the caps from going bad. When I disassembled my cap I saw no problems with it that I could see visually. Rotor looked OK to. The other side except for a little rust on the housing, wheels looked OK. Don't know what was wrong with it but the new one fixed the runability problem. I beleive it was 11 years old.
The question is, is it going to be a better product 10 years down the road......or 5. Would just like to know why it better?
1 Post
My (limited) understanding is the bearings are the main problem, in addition to the moisture getting into the early styles. MSD claims they solved both issues...
2.) The MSD unit arrives with the cap uninstalled, making sure you have the proper seal isnt just as easy as bolting the cap down onto the housing, expect problems.
In dealing with these units for 10 hours a day 7 days a week I have learned quite a bit about them. Ive said it before and ill say it again...
Originally Posted by DYNASPARK
You get what you pay for
1.) The bearings used in the stock opti are rated for 13k rpm. It is an NTN bearing, which IMO are the best sealed bearing you can buy. The problem lies deeper than a "bad" bearing.
So does that mean a stock 95 opti would be better than the msd? What specific problems did you have with the MSD. How did you solve the cap issue? I have plans for a cam swap in the future and I figured that with 80k miles I should look at the opti also. I was panning on using the MSD opti.
If not, what is different about your bearing?
Tom Piper
St. Jude Donor '03 & '05
So tell us, what is it that we can do to make ours survive?
Originally Posted by Tom Piper
Does the Dynaspark use the same stock bearing?
Tom Piper
Tom Piper
No, I have not tested an MSD, do not read too much in to what I say because you will start to wonder and then get confused, take it for what it is. My intentions are to help customers better understand these distributors and what they are buying so that they can make a better decision. I am trying not to post what MSD has done wrong with their distributor for two reasons, 1.) so they dont sue me and 2.) so they dont change it and the Dynaspark is the better choice.
I will not comment on my testing of the MSD opti.
How did I solve the cap issue? There are several issues, and how they are solved is proprietary information that I have chosen not to disclose in order to protect my business.
