Icm?
Icm?
I keep seeing the acronym ICM now which I have never seen before. Is that the same as the ECM, i.e., main computer, or is that another computer separate from the ECM. Remember, there are no stupid ?s.
zzzasy
'96 LT4
zzzasy
'96 LT4
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I haven't seen that one. I know my '95 has a PCM, (which is what the ECM became after the advent of electronic transmissions) a CCM and the module that controls the ABS and ASR. I'm not sure what the acronym is for it. I do know this though, there are far too many acronyms in the world today, we old guys can't keep up!
Originally Posted by WEH 2000C5
I somewhere picked up "ignition coil modual" for ICM .
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yep, it's an Ignition Control Module. The ICM is a small component located with the coil. It's supposed to have a heatsink grease compound behind it to help transfer heat to the bracket. If it gets too hot, it can cause performance problems.
