ALDL Cable - ?? Watt resistors
#42
This one i have here has none of them jumped, have you got enough spare pieces to give it a go Bill?
Looks like its almost the same apart from that...
#43
Originally Posted by Casethecorvetteman
Yeah mate ive read all that before. Operating systems are quirky things though, and Windows 2000 is one of the worst ones ever to come out. Lots of programs that wont work properly with it, and its just generally a very **** poor operating system. So i just thought id question that so we have covered every possible avenue.
Thanks Case!
#44
Originally Posted by Bill-35thAnvrsy-88
I totally agree and I'm convinced the serial port is good and working. Although the operating sytems are different, WIN200 and Xp access hardware (the serial port) the same way from what I understand.
Thanks Case!
Thanks Case!
#45
Thanks!
Bill
#46
Hmm, I think I read your schematic wrong. Maybe RS-232 pins 2,3,5 and 9 are not jumpered and it means to use pin 2 of 9, 3 of 9 and 5 of 9.
Hmmmm.
Bill
Hmmmm.
Bill
#47
I sure do Case. However, it appears there is some jumpering on the RS-232 on pins 2,3 5 and 9 and oddly none on pin 4 as I previously mentioned. In either case, I must jumper ALDL pins E and M together for my 88 and I don't see where your schematic is providing that either.
Thanks!
Bill
Thanks!
Bill
#48
Case...Your schematic is electrically the same as the one I'm using from Agent86 it seems. Just drawn differently.
What do you think?
What do you think?
#49
Hmmmm.
Bill
Hmmmm.
Bill
What do you think?
What do you think?
#50
Yeah but I'm currently NOT jumpering anything and...it doesn't work. My issue (and I can pretty much gaurantee) is the E/M jumpering clearly stated by Datamaster. I don't think you will have this issue. Don't you have a '94?
#51
But according to this,
there should be.... But only if it has 8192BAUD....
And also looking at this site, it shows there is too....
http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
#52
Case...I agree and I've provided a pic of my connector. I was thinking maybe I was looking at this backwards but to pull codes, I jumper pins A/B and it works fine so that would place pin M right under pin A on the bottom right. Correct?
As you can clearly see, there is no pin in the M hole...it's empty!
What kinda car I got here anyway...a kit car?
I'd sure like to see another 88 connector!
Thanks!
Bill
Thanks!
Bill
#53
Bill
Bill
#54
What I am confused about is why I don't have a terminal in Pin M !! I feel I can't go further until someone can clarify my Pin M situation! Does your 94 have a Pin M?
#55
"M" is the data line in later vettes. The reason i see them jumping "E" and "M" is it covers there *** on getting data from whatever year. There is probably nothing in the "E" terminal on later vettes.
#57
There is no PIN M.
A=ground
B=Diag Mode
E=Data
Pin E will talk in both 160 AND 8192 mode. That is why you need the 2 transistors to tell the ECM to go into 8192 mode if you want. Otherwise it will just spit out 160 baud data when you connect A/B with a 10K resistor. FYI: the difference between the two streams is not just speed, but also there is more data in the 8192 stream.
If you only interested in the shorter 160 baud data stream, why not use WinALDL. Its free, and I have found it to be less fussy when it comes to home made interfaces.
(ALSO, if anyone is interested, in between each 160 baud packet, there is a 1/10 of a second window where the ECM will "listen" for a command. There are only 2 commands; 1> clear codes, 2> go to 8192 mode)
#58
I deifnitely want the 8192 stream and I'm using the 2 resistors but I'm getting a No PCM Sync in Datamaster. I think it's a timing issue and I will tweak the ALDL timers in datamaster and see how that goes.
Woops...you said "transistors" so, I'll attach these and see how it goes!
Thanks...that's good info Topless87 and things are getting clearer!
Bill
Bill
#59
I suggest testing 160 baud stream first, its simple, and its always on and you can go to the more complex one after you have that one working.
One thing is when in diag mode, you fan should come on and you should be at about 1K RPM idle. Is you fan running? If not, you are probably not even diag mode.
(correct me if I'm wrong on this one, but my 85 and 87 both do this)
#60
