so many questions don't know where to start
Not ready to say uncle and take my 94 to a garage for diagnosis of what I expect is a bad opti...but that's slightly beside the point. I'm intrigued by the possibility of datalogging and what I can do with it to fix the car myself. Like alotta guys, it's the diagnosis that scares me. I can change any part there is, heck I've done about every automotive mechanical job known to man. I can use a voltmeter and have a sincere willingness to learn the computer stuff, but I tell ya, there's words and terms here that leave me at a loss.
Maybe a question or two to get us started...will I actually be able to use the info I get with TTS Datamaster (or equivalent) to fix my car?? Does it require a year of intense training in some GM tech school to understand terms like "speed density" and others??
I just wanna plug into the car and get a good clue of what's the problem, rather than tearing into it blindly throwing money at parts. Beyond that, I'd like to be able to throw a cam in it one day and still pass emissions.
Any and all comments welcome. First time since 1996 the car's needed diagnosis, and sorta feel like leaving it to another mechanic would be like sending my wife over to sleep with him.
There is a steep learning curve when it comes to reading and making sense of the information in a data log and there is no one place to go to learn what it all means.
As with any troubleshooting, you need to know what things should look like when everything is working right to compare it to when things aren't right.
The terms used with data logging are kind of like military acronyms, they take some time to learn and know what they mean.
Have a look here http://home.comcast.net/~khiester200035/index.html to see some of the information you'll be dealing with. The site is still in work and I haven't had much time lately to work on it.
Morley knows his stuff- may I also suggest the FSM, in my 87 FSM it has a section-Driveability and Emissions-Fuel Injection (Port)
Diagnostic Circuit Check
Below a "Scan" Data, from what I've seen it is just a beginning though.
Keep the ?s a comming though-it helps me and u and alot more.
I've got the GM manuals. Some of the Book 2 diagnostic and emissions stuff seems like Greek to me, as does some of the scanner/tuner stuff I see online. Hopefully they'll both be clearer when viewed together. Think learning the terminology would be as helpful as anything.
Was able to get my old laptop to boot up (Win ME), that's one step outta the way...IF the software is compatible with ME. It has a serial port too.
I don't think Datamaster would show the low and high resolution signal counts to help in diagnoising a defective opti spark. I don't recall seeing it on Diacom as well. I use a GM TECH2 scan tool which is a dealership tool it shows it there and while sometimes even with that it is hard to detech a problem with the opti. I always use a ignition scope to analyze the ignition wave forms and if that along with a TECH2 doesn't catch it, then I use a lab scope to watch both the high and the low resolution signals for any blips.
more to the point
So, I kind of asked this question - along with a few more - in the ECM-PCM Tuning Section FAQ (see last post, #99) -
Should a guy get a scan tool, or go for the laptop/software solution? I don't THINK I want to get into burning new EEPROM stuff, but who knows. Is there a point to using BOTH the software AND a scanner, does that combo offer anything that the laptop solution alone does not?
FWIW - I too have GM factory manuals, and I understand what I read there. Also, I hope to use my "tuner toys" on all my vehicles...
Second, the laptop/software can and will show more data at once than the little hand held scanners can. And they usually have some nice little "additional" things that they can do.
Using a scanner and laptop together doesn't work when using the traditional software that uses the ALDL for its link up since the hand held scanner also has to hook to that port. And you'd probably run into communication conflicts trying to run 2 types of scanners off the same ALDL.
Using a scanner and laptop together doesn't work....
Agreed. I guess I wasn't very clear in what I was asking; I didn't mean to suggest using them simultaneously. I'm trying to determine if there is any sense in owning BOTH a scanner AND a laptop/software setup. In other words, does a scanner offer anything that a laptop can't do, or does it do anything better than the software? Or are scanners now essentially obsolete, given that software & laptop interfaces are so powerful etc.
It seems that the hardware interfaces I've been finding are all biased to OBD II, whereas some scanners can chat with OBD I, OBD II, and CAN, when and if it comes. My 92 uses OBD I, so I am obviously looking for that capability.
Also, I don't really expect to be tweaking the EFI, timing etc; things you can do with software (even if it means burning a new EEPROM, as in my case) - but I cannot rule that out for some future time when I lose my sanity and try to improve on what I have!
I like the snap on scanners. they are user friendly. they also can be used on lots of cars.I got one on ebay fore domestic cars from 1982 to 2000 for $250. To upgrade just change the carttridge. They also tell you how to trouble shout alot of problumes. Not just read the code.
I also would like to use my laptop for scanning and tuning. I must be on low end of the learning curve. Once I start looking for every thing I need to get started I get confused.
Originally Posted by RRT vette
Not to hijack but will the handheld scanners give info like the BLM's?
I'm just in the learning, playing mode with my laptop using TunerPro RT,
but I'll tell you, setting the laptop on the passenger side the screen and display are crystal clear, not straining to see a little screen display.
and it displays an aweful lot of info. at one time-more fun later today
