PB Blaster is the deal!
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I bought some of this last year to supplement my stock of Liquid Wrench. I never really had an opportunity to give it the acid test until I did some parts removal on an original 92K mile '49 Ford the last few days. Everything I've used it on has come loose except for one manifold stud for the downpipe which did require a bit of heat. I soaked the intake and exhaust studs overnight a couple of times and when it was time to remove them, no problem. I hope the mods will recognize that I'm passing on info for a productive tool for anyone who has to take apart things that have been together for a long time. The fact that I just happened to really be impressed by it occured while working on an ancient Ford, notwithstanding. This car is really cool by the way. All original, unmolested and runs damn good. I'm just making it run better!
It's my spray of choice when it comes to removing stubborn fasteners. It smells like some kind of bug spray though.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Just bought my first can 2 days ago! After listening to my friend talk about it for years. It will replace the Liq. Wren, Pzl Penetrating, etc.
One note: my friend said he's soaked stuff with that not just overnite, but for as long as a couple days. Don't know if that would've worked in your case, Chris, but maybe next time?
St. Jude Donor '15
"In honor of jpee"
Originally Posted by SHINOBI-X
We use that stuff at our shop and it works wonders on everything to bolts,nuts,bugs,pissy attitude people,it just works!
I've been using PB blaster for a while now. My friend was taking apart his truck and I noticed him using it, said it worked really good. I use it for all kinds of stuff besides loosening bolts. Its good at lubing up stuff and preventing rust, like WD-40.
Location: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
i use it on the tough stuff, but it's too expensive to drown things in.
a while ago, i bought a gallon can of wd40 from harbor freight for around ten bucks and squirt it with an old time squeeze pump bought for a couple more. i drown regular jobs with the with the wd and use the pb for the hard stuff. i calls it love juice.
Originally Posted by Slalom4me
PB Blaster is one of a few items (along with Penray's Pencool 3000)
I have yet to be able to source on this side of the 49th.
Who wants to send me a can of it ??
Originally Posted by Corvette Kid NC
At work we call penetrating oil weasel ****. I have no idea why....
Originally Posted by AGENT 86
I haven't seen it around here either
seriously, i'd send you one, but i don't get out of the house much.
