drive shaft
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Originally Posted by mudslide
Anyone ever pull a drive shaft on a 1990 L98 conv. without removeing the c-beam??
Not on that year, but on my 1987 I just removed the rear C-beam bolts and one of the front ones while loosening the other front bolt and rotated the C-beam slightly to one side without totally removing it. It allowed me to get at the rear bolts easier and remove the drive shaft without any problem at all. I wonder if it would work on your year?
Well I finnaly got the drive shaft in with the c-beam installed but on a 1990 you have to bend a piece of a spot welded flange thats just above the shaft. It was so much easyer to get at the bolts on the beam without the shaft in the way.
