Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Old 07-24-2007, 10:51 AM   #201
RacerX70CC
CF Senior Member
1970 Chevrolet Chevelle
My Garage
RacerX70CC's Avatar
Send a message via AIM to RacerX70CC
"doing my part to keep pipe dreams alive...." TTT!
RacerX70CC is offline   Reply With Quote
Old 07-24-2007, 07:55 PM   #202
JackDidley
CF Senior Member
JackDidley's Avatar
Quote:
I think this thread may just be totally FUBARed. Hate to see it die.
JackDidley is offline   Reply With Quote
Old 07-24-2007, 07:59 PM   #203
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
OK I will give him my 406 or a 350 if he will give me the 427, and I will finish it in my car,, deal?
LD85 is offline   Reply With Quote
Old 07-24-2007, 09:31 PM   #204
hippy
CF Senior Member
Quote:
Sold, send the 406 to me and I'll hold it as the middle man.
TTT
hippy is offline   Reply With Quote
Old 09-30-2007, 02:34 AM   #205
Fubar569
CF Senior Member
Fubar569's Avatar
Send a message via ICQ to Fubar569 Send a message via AIM to Fubar569 Send a message via MSN to Fubar569 Send a message via Yahoo to Fubar569
funny guys...funny....lol
to answer some of you...
NO...it isnt fubar'ed
no it will not go unfinished
what got me sidetracked was a case of stupidity and a mild dose of joblessness which has been resolved...kinda
i'm living in pittsburgh now...which is 3.5hrs away from the car...with 400 MORE a month in bills than i had before...so to pay my old debt i had to take on more...go figure!
I have about 600 stuffed away in the bank towards my goal of finishing the car. i figure i need about 1500-2000 to finish it to be DRIVEABLE...not finished 100% fit and finish show car done...but driveable...
if i sell the laptop (i REALLY dont want to) i could get another 750 maybe towards that goal...
i'm counting on Overtime making a big return this holiday season...if thats the case, i can order all the parts by spring, take 2wks vacay...and get it running...i really am that close!
distributor, carb, fuel system, accessory drive, radiator, and shifter...
my brother has a ratchet shifter for me, and i figured otu a way to re-use the stock radiator FOR NOW...
that doesnt leave a whole lot left!
Fubar569 is offline   Reply With Quote
Old 09-30-2007, 02:40 AM   #206
Fubar569
CF Senior Member
Fubar569's Avatar
damn DP!!!
anyways...yeah im still alive...lol
Old 09-30-2007, 03:31 PM   #207
BrianCunningham
CF Senior Member
1995 Chevrolet Corvette
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Quote:
I'm still in Pittsburgh on a contract.
PM me if you want to go grab a beer.
__________________
Polo Green 95 LT1 6-spd
Mods: Upgrading as stuff wears out and/or breaks
President/Webmaster: www.baystatecorvetteclub.com
BrianCunningham is offline   Reply With Quote
Old 10-03-2007, 08:36 PM   #208
Jonnymac
CF Senior Member
St. Jude Donor '08
Jonnymac's Avatar
I'm posting this for Skruffy
http://forums.corvetteforum.com/members/229183-skruffy.html
Quote:
Sorry, I'm only half-a$&ed with wrenches .... worse with computers ... (all this is just a hobby ...)
.....(WITH REGARD TO MORE PHOTO'S) ..... I'll hopefully get one of my kids to look into it .....
Seriously speaking, the Big Block just puts the C-4 into a whole different league .....
I believe it is the most sophisticated chassis that a Big Block can be "dropped" into.
Will try to answer any Q's I can and I can e-mail you pic's if needed, as time and skills permit.
This conversion was done years ago, and not by me, so to a degree, figuring out what was done is like forensic analysis .....but it runs and drives very well, so it serves as an excellent template for those that might consider the ZR-2 (there's one in the museum) retro-fit.
1) ..... Installed a 468 C.I.D 1970 LS-6 BB that makes 92% of it's peak torque (560 ft.lbs.) between 2500 and 5500 R.P.M.
2) ...... remove A/C etc., etc., ...... Total weight 3270 lbs. 52/48 frt/rr split.
3) ......Installed ZF6, from ZR1.
4) ....... Installed B&M short throw with grafted on custom ebony Pistol grip assembly from Hemi-Cuda ... (it's nice to have something you can really get a grip on)
5) ..... Hoosier R-6
6) ..... slammed with full Corvette Challenge susp.
very simple to work on.
...should pull over 1.3 lat G's ... drives around Ferrari's ....
HERE IS AN EXAMPLE OF A TECHNICAL ISSUE WE WORKED OUT:
Did you do anything with the Clutch Master or slave Cyl. in your swap?
In my case, the combination of parts from the '85 and the '93 seems incompatible and we think that the slave was used from the ZF6, and now in a pusher configuration, but the master was the orig. from the 4+3 which has a spacer block between it and the firewall.
This block was preventing the Master cyl from 27.5 % of it's potential displacement (that's all GM needed from it to work the 4+3), however , that was insufficient for the stroke required by the ZF6 slave cyl., so the clutch was never right and no one was able to fix it until we figured out this basic flaw.
This was possibly responsible for clutch failures that all look like you describe yours.
We milled the block down to get the full displacement and no problem now.
Also check your clutch pedal pivot point rod. They are a very soft steel that typically will be found with up to 1/2 of it's diameter worn away ( because of the hardness of the Master Cyl. piston rod end) which is magnified at the far end in reduced slave cyl. stroke.
Getting the pedal assembly out is one of the worst jobs on a C-4 but it is absolutely necessary.
Drill out the old rod and reinstall a shoulder bolt in its place.
I can now change and/or inspect my clutch pivot in less than 5 minutes.
Jonnymac is offline   Reply With Quote
Old 10-03-2007, 10:58 PM   #209
Skruffy
CF Member
Location: Kingston Ontario. 85, Z51, DRippie's actual '87 SCCA Fox RShox, 523cid BBC ,C4-ZR2, ZF6, HoosierR6, Plated.
My Thanks to Jonnymac for assistance in getting the above information on this thread.
The "ZR-2" Big Block C-4 conversion is a remarkable combination.
You can see "ZR-2" Number 1 in the National Corvette Museum.
It will require that you either possess the fabricating skills of the average street rod builder, or know and have access to people who do, who will help you.
This vehicle has an incredible balance of power and handling. It is an excellent value, particularly when you consider that if you start with a "flood chassis" for peanuts, plus time to shop efficiently on e-Bay for all your bits for example, you can have supercar performance for well under 10K.
I will attempt to help anyone trying this project by reporting what has been done with this vehicle (as best I can), which should be an advantage over speculating about what might need to be done.
Skruffy is offline   Reply With Quote
Old 10-04-2007, 04:43 AM   #210
Fubar569
CF Senior Member
Fubar569's Avatar
Thanks for chiming in with the info!
as stated it's really not hard...just takes some cash and a leap of faith
Old 10-04-2007, 09:53 AM   #211
Skruffy
CF Member
Thanks Fubar ...
It seems as though I live about 6 or 7 hours driving time from you, so we'll have to organize a "ZR-2" meet.
Also , when you are ready, I have connections at the track at Watkins Glen (which isn't too far for you) for test and tune time. When the track is not booked, my contact will fit us in for cheap. ....we'll call it the "Rat Run".
Old 10-04-2007, 12:49 PM   #212
Fubar569
CF Senior Member
Fubar569's Avatar
Quote:
Originally Posted by Skruffy View Post
Thanks Fubar ...
i am hoping i can get it running by corvettes at carlisle next year...that is my goal every year but i seem to get sidetracked every time...lol
my interior will be either extremely ratty, non existant, or completely stripped with a cage...i haven't decided...depends on cash...
Old 10-04-2007, 05:10 PM   #213
TONYDEE64
CF Senior Member
TONYDEE64's Avatar
If you're up for a challenge, try doing a big block conversion on a C4 with a supercharger......... all under the stock hood....
TONYDEE64 is offline   Reply With Quote
Old 10-04-2007, 05:10 PM   #214
TONYDEE64
CF Senior Member
TONYDEE64's Avatar
come to think of it, just do a killer small block with turbos... save the headache...
Old 10-04-2007, 06:05 PM   #215
orangec6
CF Senior Member
orangec6's Avatar
Default March serpentine setup
I have a BBC March serpentiine setup with accessories for sale. Had it on my BBC C4. See racingjunk.com, search for March.
__________________
Racing because baseball, football, basketball, bowling, tennis and golf only require one ball.
1990 Corvette - Charcoal Grey Coupe.
All motor!!!
1/4 9.85 @ 144.44mph
Standing mile Maxton, N.C. www.ecta-lsr.com
AA/GMS record 191.44 MPH
AA/GT record 203.21 MPH
AA/GSS record 173.41 MPH
www.3cracing.com
2003 Silverado SS - Arrival Blue.
2006 GTO - Cyclone Grey.
2006 Z06 - Daytona Sunset Orange Metallic.
orangec6 is offline   Reply With Quote
Old 10-05-2007, 05:31 PM   #216
Fubar569
CF Senior Member
Fubar569's Avatar
wowzers on that serp setup...i bet it looked nice under there too...i just...man i wanna spend the money on it but....man...lol
Old 03-16-2008, 01:42 AM   #217
Fubar569
CF Senior Member
Fubar569's Avatar
FUBAR IS ALIVE!!!! MUWAHAHAHAHAHAHAHAHA
so sorry for not making serious progress in almost 2 years on this car. I have a ZIP file of all pics up to this point for anyone interested!
As it sits, i am carb, fuel system, accessory drive, and distributor away from a running car. my stepbrother donated the B&M Megashifter from his Firebird so i am going to fit that to the vette console.
My Economic Stimulus (read: vette stimulus...rofl) is going towards accessory pulleys and brackets for the power steering. when i started this project i had a bastard time finding pulleys for a SWP BBC. Now even summit has some!
I engineered the front of the car around running a Black Mountain Precision 1" wide Cog Pulley accessory drive, but now March makes serpentine pulleys for use on SWP BBC applications in both underdrive and OD Waterpump configurations. i am truly torn now as to which way to go. I NEED to call MARCH and get the dinensions of all applicable pulleys that fit SWP BBC apps and make a formal decision. I believe i am going with the BMP Alternator bracket and relocating the alternator to the Passenger side where the AC used to be either way, but i wont know til i get the pulleys ordered and bolted up to check alignment and whatnot. IF all else fails i KNOW standard V groove pulleys will fit without issue.
Car will be actually PAID OFF by june hopefully so thats a couple hundred extra per month into Mods to get it done. i am working for near minimum wage right now which blows but it covers my essential bills so i can get things back together in my life...it's been a crappy 6 months or so...moved away from home, lost a GF, moved back, lost another GF, couldn't get a job till the end of feb (moved back in dec)...yeah...fu8n times...but i WILL make a comeback...and I PROMISE TO FORGE FORWARD WITH MY PROJECT AT ANY COST!
just wanted to let you all know i am alive and well...and i will be starting to work on it again soon!
Dave
Old 03-16-2008, 02:11 AM   #218
xrcrx
CF Senior Member
xrcrx's Avatar
Hang in there! Glad ya havn't given up on the dream. Lickily I got my project finished in 11 months, but I understand never ending set backs! Lookin' forward to seein' the finished product, and best of luck with better employment and averything coming back together
xrcrx is offline   Reply With Quote
Old 03-16-2008, 02:22 AM   #219
Fubar569
CF Senior Member
Fubar569's Avatar
Quote:
i will NEVER give up on this dream...man i have too many blue oval fanatics and vette haters around here to prove wrong when it's done!
i'm hoping to get in touch with a few people in the near future...btw...how has jesse's attempt at 4 link kit for C4's been doing? i saw his in person at the dragstrip during the summer for the maiden voyage...totally hooked and took off like a rocket!
i know the D36 will not last once the 315's go on the back, so it IS in my future...lol
Old 03-16-2008, 03:29 AM   #220
xrcrx
CF Senior Member
xrcrx's Avatar
I'm sweatin' the D36 in mine now that the 383 is in. I installed 3.75's a while back. I'm running BFG DR's in 315 so i'll let ya know how it fares.I also have a 3k stall from Pete K. He said it'll take a bit of the shock off the rear, I'm hopin' it's enough.if I can be sure of everything I'm gonna make the trip to Richmond again this year for the Corvette Nats. it's a bit of a drive from Houston but well worth the trip.
Reload this Page 427 BBC Conversion FINALLY Started!!!
Tags
427, 427high, 496, 632, bbc, big, block, c4, conversion, corvette, deckbuilt, engine, estimated, horsepower, kit, swaps, truck
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
