700r4 gurus need your help!!
My dad's vette 89 auto.
Yesterday got the vette out and went for a drive, when the vette changed in overdrive at about 40mph i gave it some gas to pass a car and the engine just revved to 2600,3000,3500rpm with no accelaration, i tought that the clutches were slipping and it was doing this in od only. 1st 2nd 3rd there was no slippige the car just accelarated beautifully,only in od it slipped. This is the third time in a year and a half that the tranny has slipping clutches and when i talked with my mechanic he thinks that this could be something to do with the tourqe converter, he told me that pieces from it could be going inside the tranny and they are making some kind of damage to it.
Sorry for my english.
Cruise-In V Veteran
Originally Posted by Damien89
Sorry but i do not know what do you mean?
From the sounds of it, your 3/4 clutches may be worn out. The 3/4 gear ranges use a seperate clutch pack. This pack is prone to wearing out first. During a rebuild, this clutch pack can be upgraded. This is of no help to you now, unfortunately. I would take it to a local tranmission pro, and let him take pressure readings. There are many pressure ports on the outside of the trans. Readings can be taken and compared to specs in the shop manual. This will allow him to verify the tv cable is set correctly and the clutch packs are holding pressure or not.
ttt
Why u put "ttt" when already a tranny guru told u so thats pete. K he is the only expert on CF others have knowledge but pete has mastered in trannies and so far he has build tranny's for hundreds of people both on forum and outside including mine. No need of ttt any more please.
ttt
LOL..... oh no the "ttt' police have arrived to highjack the thread from innocent posters and pretenders. gimme a brake, ...... or a rotor...... Some people are so serious. Why not bust me for putting a link to a non FORUM supporter. I will not post again in this thread, so don't even bait me....
What puzzles me is that the tranny was working fine then all of a sudden the shift from 1st to 2nd was jerky and after i drove it for 5 mins the od started slipping. If this was a case of an uncorrect t.v cable that was not set to the proper specs wouldnt the tranny act strange from the first time that i drove it from my mechanic? Why now after 2 months? Can it be that the torque converter or something else is going and there are pieces of debry in the tranny which is causing it to not work properly and causing these symptoms.
I had the same problem and continued to drive the car, then one fine day the transmission decided to die right on the GS parkway, imagine that, right on the parkway. It took an hour to wind the car home.
Good luck with the rebuild.
It does not happen often, but the TV cable can move out of adjustment, and when this happens, changes occur immediately as the line pressure has now changed in relation to the throttle (torque output). Usually though the shifts get longer and sometimes a slide shift, but what you have can happen. I would check the TV cable setting, check the fluid level & condition of the fluid, all of these are important to the life of this unit. I have built 100's of 700R4's, for HD & Hi-Performance use, and this (the TV cable setting) is critical. The torque converter is most likely not the cause for this. As Pete K said, take readings, and see what you have.
