Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-14-2006, 07:29 PM   #1
illinest
CF Senior Member
illinest's Avatar
Default chassis flex fix?
the car twists more than i like, (86 vert)
how do you make the chassis more stiff without making the ride more stiff?
elementary knowledge level please.
illinest is offline   Reply With Quote
Old 03-14-2006, 07:33 PM   #2
Redeasysport
CF Senior Member
St. Jude Donor '05-'06
Redeasysport's Avatar
Send a message via AIM to Redeasysport
Buy a RD Racing cross frame problem solved.
Redeasysport is offline   Reply With Quote
Old 03-14-2006, 07:59 PM   #3
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
C4 Verts should have an X-brace from the factory. The factory brace not only attaches to the corners of the frame, it also is bolted to the floor pan in (IIRC) 6 places; 3 bolts go thru the floor pan on each brace.
c4cruiser is offline   Reply With Quote
Old 03-14-2006, 08:04 PM   #4
chucks88
CF Senior Member
chucks88's Avatar
I've been fighting this to...These are the things I have done all of which has helped
Lowered car
larger sway bars
new bushings
camber brace
new shocks
chucks88 is offline   Reply With Quote
Old 03-14-2006, 08:04 PM   #5
Redeasysport
CF Senior Member
I missed the Vert part.You can modify your brace by boxing it in with 1/8 X2 in. plate welded to it and it will strengthen it.
Old 03-14-2006, 08:06 PM   #6
95wht6spd
CF Senior Member
95wht6spd's Avatar
Camber Brace and Cross-bar solved my flexing problem.
95wht6spd is offline   Reply With Quote
Old 03-14-2006, 08:10 PM   #7
Corvette Kid
Large Upstanding Member
St. Jude Donor '04-'05-'06-'07
Corvette Kid's Avatar
Location: Not a loser who defines himself by being the 10,000th poster in an "epic" thread
Quote:
Unfortunately, R-D doesn't make a roll bar for the verts. They are a great asset too. You vert guys just have to have one fabbed if you want to go that route.
__________________
KTN
Corvette Kid is offline   Reply With Quote
Old 03-14-2006, 08:25 PM   #8
vader86
CF Senior Member
vader86's Avatar
Camber brace would be the first step, there are rollbars available from other places than RD and that would be the 2nd step.
Larger sway bars would also help somewhat.
vader86 is offline   Reply With Quote
Old 03-14-2006, 09:57 PM   #9
illinest
CF Senior Member
illinest's Avatar
http://www.r-dracing.com/camberbrace2.jpg
http://www.r-dracing.com/cbv1.JPG
http://www.r-dracing.com/cross-frame_001.jpg
Good information guys. Thanks!
Reload this Page chassis flex fix?
Tags
c4, chassis, corvette, fix, fixing, flex, flexing, frame, repair
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C-3 "tube frame" redvetracr C3 Tech/Performance 13 04-24-2004 01:56 AM
Who makes C4 roll cages? Eirewolf C4 Tech/Performance 23 10-31-2003 12:43 PM
C-3 Chassis Flex TPIShark C3 Tech/Performance 89 12-23-2002 03:10 PM
How to fix 4 speed shifter rattle????????? tuxedo C1 & C2 Corvettes 15 10-09-2002 09:26 PM
Anyway to stiffen the chassis? 94 M-6 C4 Tech/Performance 46 06-17-2002 06:14 PM
C4 road race suspension input needed C4RACER Autocrossing & Roadracing 48 05-28-2002 09:30 PM
Body flex vette_guy C4 Tech/Performance 11 01-02-2002 01:52 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
