Bosch Spark Plugs
iv heard the same thing. i run autolight race plugs in mine. part number ar3924. good luck. the difference over oem not really sure. i have a racing buddy with a 69 camero that recomend them.
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I run Bosch plats (standard) in my DD, never tried them in the Vette. Never tried the Plus 4 models, either. Use the NGK TR-55 Platinum instead.
In Lincoln Tech one of my instructors was a Chevy Tech, he said that a lot of cars with the +4's came in and apparently the platnum electrodes fell off, and then tumbled around inside the motor and scuffed up the bores. You couldn't pay me to run those plugs.
Oh ok. Guess ill take them out tomorrow. Lucky me. Its a pain to change the plugs on the drivers side even with a swivel wrench and im not paying some overcharging mechanic to do it. Thanks for the info
Originally Posted by gslotman
I am with F92 on this. I tried the +4's - and mileage went down (shrouds the flame path from plug).........went with my old stand by TR-55s and mileage went right back up !
there are two diffrent tr55 one platnuim and the other is iranuim
Which would be better? Iranium sounds like it is better but not price wise.
What gaps would you recomend with both options.
I use the bosch platnuims regulars. but they are gaped to .045 instead of .035 When i used the stock gaping my gas milage went down so i gaped up till it ran better.
does the year actually matter when choosing plugs? I know ingnition volts and the heads do matter.
I was looking for the TR 55 duoble plat and i was not able to find them for my application.
1989 L98 ,alum head
I did find diffrent NGK's called V-power.
Any advice on these?
http://www.modulardepot.com/product_...bd9be2de695594
1989 L98 ,alum head
1989 L98 ,alum head
1989 L98 ,alum head
Check your service manual, but I think the stock plug gap is .050
