Anyone recommend Optima Battery for 91 Coupe?
Anyone out there who has had experience with an Optima battery. Have been told that they are very reliable and that the "Yellow Top" has some deep cycle
advanges over the "Red Top" Optima. Anyone know were to get them?
Re: Anyone recommend Optima Battery for 91 Coupe? (Carroll Floyd)
I looked into this no too long ago & found that the these batteries, which use
the spiral cell technology, are not yet made to fit C4's. Something to do with
a interference problem with the top of the battery with the, I think, cruise
control hardware?
I was interested in this after reading that they are using this battery on the C5, & it reduces weight while having a high energy density.
control hardware?
Re: Anyone recommend Optima Battery for 91 Coupe? (foliva)
Just put one in the 92 and had to cut one of the top post off
to clear the bracket the ecm sits on. Other than that I think
I'm going to like it. :D :cheers: :D
:chevy :chevy :chevy :chevy :chevy :chevy :chevy :chevy
[Modified by CEEFOUR86, 8:12 PM 8/8/2001]
hmmmmmm
i have one in my '85 coupe, maybe a little different than your later years.
mine is a red top and the part number (just took it off the battery) is
75/35-925......model number is 8022-091 fits like a glove!
Re: Anyone recommend Optima Battery for 91 Coupe? (85_togo)
The red top is great. I would stay away from the yellow top (deep cycle) battery. I had a yellow top and when my battery drained because of the lights being left on, I couldn't jump start it with another car. With the deep cycle batteries, you have to recharge it with an A/C Battery Charger. The red top isn't deep cycle, so it works well.
-Tim
-Tim
I would stay away from Optima's in Vette's from my personal experience. I have had Optima's in 1990 S-10 blazer, 1996 Yukon with great results, but it didn't like my 1990 Vette. I had numerous problems with it, wouldn't hold charge, and it bench-tested fine. I replaced it with a sears die-hard gold series, and it is perfect. I have used sears die-hard gold series before, Interstate battery, and Optima in my Vette over the past 11 years. The sears gold series is the best. I am running a 160 amp alternator and modified motor, so this may acount for the problems, but why spend double and tempt fate!
By the way, it fit fine in my car, tight, but fine.
Optima doesn't list a correct part # for later C4s... I did put one of comperable physical size in my 96 but had to make some modifications...
1. The Optima is about .5 - .75 inches wider, so I had to cut the sides of the battery tray down to make them flush with the baseplate so that it would sit down and I could use the stock battery hold down...
2. I also had to notch out the cruise bracket so that the top + post wouldn't contact it... Here's a pic...
It's been a good batteery for me though, I've had it for almost 2 years... It's an 880 CCA model compared to the stock 530 CCA (I think)...
got a optima yellow top for my 95 vert .cut notches in the battery tray to make it fit. works great. have a little interference with the top positive post hitting the brace.Slipped a rubber dampner in between them and it's fine.
:chevy
:chevy
Re: Anyone recommend Optima Battery for 91 Coupe? (gottaspeed)
:chevy
:chevy
Jim
I put in an Optima red top a few weeks ago.
No problemo :D It works great.
I have one in my 89 vert But its the only top post battery I could get here in japan with out paying an arm and a leg for shiping cost me $120.00 anything else they were talking over $200.00 :crazy:
But as for holding a charge?? its holding one better than the ac delco one I removed It was the original heheh
anyway it fits fine in my car.
Re: Anyone recommend Optima Battery for 91 Coupe? (phrogs)
I have red tops in my 84 and 86. work great, had to trim batty tray a small amount to get to fit, but otherwise no problems
