Do Not Use Sae 10w-40 Oil
Old 02-04-2006, 11:27 PM
halifax
halifax's Avatar
Default Do Not Use Sae 10w-40 Oil
DO NOT USE SAE 10W-40 OIL That is what the 1985 Corvette Users Manual says in BIG BOLD LETTERS.
5W-30, 10W-30, 15W-40, 20W-20, and 30 are all OK, but not 10W-40. Why not? I've been using Valvoline 10W-40 for 30+ years and this is the first time I've seen a warning like this.
Old 02-05-2006, 12:37 AM
kopbet89c4
kopbet89c4's Avatar
Old 02-05-2006, 01:20 AM
mstock
mstock's Avatar
Default Perhaps...
It seems like I read here somewhere that it had something to due with vicosity breakdown(back in 85). 10w40 as i recall, was not very stable back in 85. As they have inproved the formulation over the years, stability has increased.
Old 02-05-2006, 01:25 AM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I was surprised to read the same thing.
Old 02-05-2006, 01:37 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
10/40 is all I use in my 89 (Dino oil), an same grade Mobil 1 in the Z?!
Old 02-05-2006, 01:47 AM
VenkmanP
VenkmanP's Avatar
Covers too wide a viscosity range. Jack of all trades master of none. Notice that all the rest have a smaller range.
Google is your friend. I'm sure this is in every oil FAQ out there.
Old 02-05-2006, 03:01 AM
CentralCoaster
You musta missed this thread, similarly titled:
"Do not use Sae 10w40 oil"
http://forums.corvetteforum.com/show...m_id=48&arch=1
Old 02-05-2006, 08:47 AM
mseven
mseven's Avatar
If it was the logic of the point difference (or spread) than 0-20 on a motor tight by design would not be good either. Additives to support weights is a possibility also, but for the most part I believe it is about clearances, therfor the nessecity to get the oil to lubticate everything. New production (last 15 years on so) tolerances are different than motors that were built in the 60-70's.
Old 02-05-2006, 10:24 AM
halifax
halifax's Avatar
Odd. I did a search before I posted. I must have done something wrong because this didn't come up.
Old 02-05-2006, 11:58 AM
Muffin
Support Corvetteforum!
Muffin's Avatar
First, I can't find such a statement in my Service Manual, GM ST-364-85. I recall reading somewhere about " molecular strings" in oil. Larger the spread,10-40, longer the strings and more subject to break down.
I will not argue with the experts but 10-40 hasn't let me down for more than 40 years so I'll stick with it. I am building a 383 to go in my 85. It will live on 5-30 Mobile 1.
Old 02-05-2006, 12:17 PM
Strike3
Strike3's Avatar
Bottom line guys! Both this and the old thread dances around the issue, sometimes touching it but never quite right on.
All 10w40 oil was recalled about the time of the 85 cars were introduced due to failure in engines. It had been out for a while and there was tons of it on the shelves of every kind of store from the 7/11's, to the grocery store, to the big auto parts stores across America. Auto manufacturers were well aware that the recall would fall on deff ears at most places except for perhaps the big auto parts stores and gas stations, and they didn't want to run the chance that some of the stragler packages of 10w40 might be aquired and put in their cars. Especially since the Oil companies were trying there best to keep the recall quiet, if for no other reason, to avoid everyone in the U.S. who has an engine burn up, blame them and sue.
The cause of the failure was the newly developed pollimer package which had been developed to produce that 30 point spread in viscosity.
The new formulation had flaws and broke down under certain situations and lost it's lubrisity, and allowing metal to metal contact.
I can only assume that these problems have been long solved are the oil company's would not have put it back on the market and invited further suites.
However, to this day I will not use a 10W40 oil in my car.
Old 02-05-2006, 12:26 PM
Soggytaco
Soggytaco's Avatar
Originally Posted by Muffin
I will not argue with the experts but 10-40 hasn't let me down for more than 40 years so I'll stick with it. .
5W-30 tells you the oil's thickness, or viscosity. A thin oil has a lower number and flows more easily, while thick oils have a higher number and are more resistant to flow. Today’s High performance engines have such tight tolerances that you need slightly less viscous oil in order to properly lubricate all of the critical parts.
Feel free to use what ever oil you want, but don’t be surprised when your engine shows signs of premature wear.
As far as using a product for 40 years 40 years ago people thought smoking cigarettes was good for you times change.
Old 02-05-2006, 05:21 PM
halifax
halifax's Avatar
Ok everyone. Thanks for responding. I think next time I change oil I will go with the Mobile I 10W-30. I'm already using their filters.
Old 02-05-2006, 11:20 PM
MrRenoman
MrRenoman's Avatar
After my engine had over 100K miles, it didn't bother me to put 10-40 in only because the tolerances had increased due to wear. I still use it in some of my cars.
Art
Old 02-06-2006, 01:32 PM
rocco16
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
This is what I understand as well.
I've read that more than 20point spread on a multi-viscosity oil means the oil is not as "stable", or something along those lines.
This was the current thinking as of ten years ago ....it may all be changed by now.
Larry
code5coupe
Old 02-06-2006, 01:37 PM
89sleeper
89sleeper's Avatar
Location: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
I run 0-40W Mobil1 in my 89 coupe that has a 383 under the hood
Old 02-06-2006, 09:06 PM
redrose
redrose's Avatar
don't know the ''theory'', but...
long long ago, bought a new 77 caprice...first oil change put in 10-40...car used a quart of oil every 1k for months...went back to dealer and was told not to use 10-40...changed to 10-30 and oil consumption ceased completely
To Do Not Use Sae 10w-40 Oil
Quick Reply: Do Not Use Sae 10w-40 Oil
