Yow! %$@ wipers
Yow! %$@ wipers
Two weeks ago I noticed that right around 70mph and over, my drivers side wiper was stroking way faster than usual. The symptom has progressed to the point where now, over 70 with the wipers on in any position, I get half the blade hanging off the windshield and the arm is crashing into the metal moulding around the windshield and taking paint off!
I haven't had a chance to look at the wiring diagrams yet but anyone have a clue what could be causing this kind of behavior?
Thx
Thx
You don't mention the year.
earlier units have rather weak springs to hold the wipers to the windscreen. But that does not answer this problem.
There is an adjustment that can be made. The bolts that hold the wiper arms to the cowling can be loosened and adjusted.
Judging from you are describing, there is some wear in the wiper arms. I would not be surprised if the rod that actuates the arm, or, the motor itself, is worn or wearing out.
duh, it's a '95. 175k miles and the last 70k of them here in Seattle so the wipers have been getting a good workout.
Worn mechanical parts, huh? OK, thanks for the clue.
Cheers,
Jay
Cheers,
Jay
St. Jude Donor '05-'06
Originally Posted by JayH
duh, it's Seattle
Cheers,
Jay
Cheers,
Jay
Probably got worn out in the last month the way you guys have been getting soaked.
JayH, were you able to fix this problem? My wipers don't necessarily go faster at high speeds, but at high speeds the drivers blade does go past the pilar, and scratch it.
Which part is the worn one that should be replaced?
thanks
thanks
I just fixed this on my 86'. The driver's side wiper would go beyond the winshield and the top 3 or 4 inches would be sticking out off the side of the car.
I watched Gordon Killebrew fix my friends 86' at the Forum Cruise In last year(Fozzy_Bear's car). Where the wiper blade attaches to the motor there are 2 10mm bolts in slots. You can loosen the 2 bolts and pull the wiper toward the engine and then retighten them.
When Gordon did this to my friends car I was shocked and amazed at how far he pulled the wiper into the engine compartment! It worked like a charm after that, though.
Remember to do all your testing/measuring with the motor running as the voltage increase will affect the swing of the blades.
C4 of Year Finalist (appearance mods) 2019
Remember one other thing; when you loosten those nuts be careful. I believe the spacing and positioning is such that if the nut comes off it will be darn difficult to get it back on....so just loosen
You need to loosen the 10mm nut on the wiper arm for the driver's side and push the wiper down a bit, kinda past where the blade rests. Keep and hold it there, tighten back the bolt and then your driver's side wiper should be back into position without hitting the A-pillar. Worked perfectly for me.
Funny story that goes along with this:
I was at the local dealership planning on having them adjusted and I was yelled at because I wasn't supposed to ask a dealer repair technician on how do it so my service advisor could charge me 2 hours of labor to adjust them. F*** that!! I didn't let him charge me because I asked for my keys back as soon as I overheard the foreman tech explain it to the stupid tech. While they were busy conversing, I read the tech manual that was sitting open right on top of my tire and learned in 20 seconds! Then off I went, adjusted them in a couple of *minutes* after I arrived to my work place. I was mighty glad I spared myself $194.74 of Corvette tax. F*** Michael Holley Chevrolet in Lakeland, FL!!!
I haven't even looked at mine yet.
I don't see how it could be a placement-setting-adjustment as the wipers retract fine every time and only end up off the windshield at high speeds - and even then, it doesn't happen with each sweep.
The speed of the sweep is also a lot greater when it happens. Before the wiper even gets an 1/8 of the way through its sweep, I know if it'll end up off the windshield or not by how fast it takes off.
I think I'll break out my FSM tonight and take a look.
THe wiper is lifting off the glass at speed from a worn tension spring. You can remove the spring from the wiper arm and probably find a replacement at Home Depot or Lowes.
Mine does the same thing at highway speeds. I have tried adjusting with the 10mm nut. I have also tried longer and shorter blades. No cure yet. I haven't tried a new spring yet though, new idea. Thanks.
My vette is my daily driver, and I live in Seattle!
I would expect a more consistent showing of the problem if it was a weak spring, but there's no telling whhen a sweep will be fast and off the windshield or when it will act like normal.
At this point I'm thinking a failing voltage regulator, windshield wiper motor assembly control board or related component, or a worn cam on the mechanical arm in the assembly.
Originally Posted by drochau
you mean...you guys....drive...a....corvette....IN THE RAIN??!!!!?!?!
Mine's a dd here in Seattle and so the wipers are used 7 - 9 months a year. Never had this issue but yep particularly C4's don't tend to melt in the rain
Damn guys, I'm using the factory 20" blades! Yeah, I adjusted them good enough that they don't collide with each other nor go off the A-Pillars. I'm glad that it only took me minutes, not hours to adjust them perfectly.
