got a coolant leak
got a coolant leak
I have a coolant leak that I cannot get rid of, it appears to be coming from the lower radiator hose, but I replaced the hose, the clamp, and still leakage, it only leaks after it's been running though, like when there is pressure. I cannot see any leaks, or cracks, is there a common place where it comes from in which you cannot see, or could I just be blind, any help is appreciated as always.
Originally Posted by TM-96CE
Stock radiator? Chances are he plastic end-tanks are starting to crack. If so, it's time to order a Dewitts.
RACE ON!!!
Cracked end tank by the lower hose connection. You won't able to spot it cold but it can gush under pressure as the crack opens up. I'd suggest a new stock type replacement unless you plan on road racing.
Jason
Jason
You can buy a radiator pressure test kit, or make our own. If you pressureize the radiator you should be able to pinpoint the leak. MityVac makes a tool that goes on where your pressure cap goes and has a fiitting that allows you to put pressure in the system. You COULD use an air compressor but BE VERY CAREFUL about how much pressure you use, look at your pressure cap. 10 to 15 lbs.?
Thanks, yeah they have those pressure testers at grease monkey so I'll try that first, the hose that I replaced goes from the thermostat to the lower radiator, like said can't see a crack even hot just seems to drip at the hose, and it's kinda hard to tell if it's anywhere else cause it gets blown around under the car and by the fans when i'm driving, and it doesn't leak if I'm not, so I guess it's time to pay some money, I just replaced a 89 firebird radiator that was $110, how do you think money and difficulty is compared to that?
The replacement is not a difficult job. There are three screws in the front on each side joining the upper shroud to a lower piece that are difficult to get to, but that's really the onlt thing that is difficult at all.
Jason
Jason
