L98 to LT1 intake conversion?
Old 12-29-2005, 01:53 PM
silver86
silver86's Avatar
Default L98 to LT1 intake conversion?
Just curious if anyone has ever tried this, or if it is even possible on an '86 cast iron head L98.....
Old 12-29-2005, 03:06 PM
q2blaster@work
q2blaster@work's Avatar
Default Check This Link
This link should tell you all you need. I didn't like the way you have to run the remote thermostat, but thats just me!
http://www.lt1intake.com/services.htm
Old 12-29-2005, 04:52 PM
Corvette Kid
Large Impressive Member
Support Corvetteforum!
Corvette Kid's Avatar
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've got a friend who has one on a built '85. He's very happy with it and it's a strong runner.
Old 12-29-2005, 05:00 PM
MrNuke
MrNuke's Avatar
Search on the THIRDGEN.ORG forum. Few people tried, even fewer got it to work successfully using a converted LT1 intake..
Good idea, I'd be doing it if it didn't mean no Emissions, chances of eaten distrbutor gears and coolant leaks, remote thermostat , need for smaller distributor, etc..
Old 12-29-2005, 05:30 PM
rlane5
rlane5's Avatar
I have a conversion, I did most of the work myself with the exception of welding extra metal around the water jacket for extra insurance (no leakage) the advantage of a conversion is to allow the engine to pull more air at high RPM, if you have head work and a higher revving cam you will see a BIG differents. I pickup 5 mph in the 1/4 doing it, which result in 50 hp or more doing that. check my web page
Randy
Old 12-31-2005, 05:45 PM
dirtnapp
dirtnapp's Avatar
I am in the process of doing the same thing. Randy, how did you get the bigger distributor to fit? Did you machine the egr ports off? I am considering doing that because I don't want to set it up for remote coil application.
Old 12-31-2005, 06:50 PM
rodj
rodj's Avatar
Working on one at present.
If you cut away EGR boss completely you only have to cover a hole 1.5 x 2 where the exh gas went under the runners.You will need custom lines ( a -AN fitting on each rail )with the large HEI as the large cap won't clear the stock lines.
As above I am going to weld extra material above the stock water jackets as there is little room for error and the LT1 manifold is a lot lower than stock in these areas.
Have pics if you want to email me
vetteoz@optusnet.com.au
To L98 to LT1 intake conversion?
Quick Reply: L98 to LT1 intake conversion?
