Power diff between Corsa 2.5 or 3 inch on stock LT1
I'm getting ready to purchase a Corsa exhaust for my stock 95 LT1 6sp. I have a choice between the 2.5 inch system and the 3 inch system. Does anyone have anyone have experience with both. Which one did you purchase?
going to go out on a limb, and say 3.0 inch piping isnt necessary for stock LT-1 that dyno's around 265rwhp in stock trim. i would think 2.5" is plenty.
Well, fist off Corsa doesn't make a 3" inch system for C4's, only 2.5"...unless the 3" is brand new, and I would really like to get it! But on a stock LT motor you really don't need it. Do you plan on doing any major engine upgrades like heads/cam or stroker later?
C4 of Year Finalist (appearance mods) 2019
Originally Posted by 93 ragtop
2.5 may well be enough, but I gotta ask. Why did the factory use 2.75 pipes?
Exhaust wise the limits are the factory headers and cats....not the cat back portion....so very little (10hp) can be gained with cat back only...
I would pick based on looks and sound and of course cost...all else being equal bigger .....so I am running 3"...but not Corsa...so don't really know answer to your question...
Do you spend alot of time ubove 5,000 RPM? If not i cant see the advantage to a 3 inch on a stock standard car,(you may notice the bigger diameter made more power but at higher RPM) and in my opinion, 2.5 inch system would better suit the stock config unless youre planning to supercharge or internally modify in terms of displacement/cam/porting etc (as stated by Mr. Peabody) Without changing the stock manifolds and cats for free flowing type ones, 3 inch is almost a total waste of time anyway. Going too large may even result in a slight fuel economy loss.
If you go too big with the exhaust , you'll really slow down the flow of exhaust throught the system which is not beneficial. One benefit of the 2 1/2" is the fit, better clearances, easier to install. Yeah, listen to me with a 3" B&B catback on my mostly stock LT1, but I love the look.
Thanks for the replies. I am thinking about long tube headers and free flow cats. Probably do them in the near future. If finances allow, I will eventually upgrade the cam and heads. I would like about 350-400RWHP. I dont think the 2.5 inch system would prevent this, but I just wanted to hear what others had to say.
When I orig. modded my motor, I did the cam, heads, and LT headers, but kept the stock exhaust. It actually sounded pretty good. Its deeper in the tone area, and its louder. I believe it was Nathan who had a friend who did the same and liked it.
Anyways, I have tried the above combo, removed the stock resonator and installed 2 bullet cats in their place, and tried the Magnaflow mufflers as well.
To the best of my ability, checking drag racing slips, there is no difference in the systems as far as performance goes. Orig. I thought the cats slowed me down 1 tenth but it turned out to be bad plugs.
The bottom line I am getting at, is if you plan to do headers, Id do them now instead of the cat back. With these you will see a power increase and better sound, IMO the catback will only help sound and looks.
Originally Posted by Admiral94
The exhaust will only flow as much as the smallest openning.
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
You may slow down the velocity, but you won't decrease the volume of flow(CFM).
Larry
code5coupe
FWIW, he claims he picked up 14rwhp going from 2.5" to 3" around the 400rwhp level.
Originally Posted by rocco16
How do you figure?
Larry
code5coupe
Larry
code5coupe
I don't like the idea of reducing from factory 2.75" to corsa 2.5"
that just does not make sense... and doesn't leave room for HP gain with future mods.
I had the same issue with my F-body. I have an all stock 3rd gen 5.0L Fbody. The muffler rusted out.
The factory was 2.75", and some aftermarket were 2.5".
but I searched until I found a 3" cat back. and going to 3" did not reduce power. MPG went up, low end torque went up, etc. Bigger is better, especially with the restriction of the CATS.
Received 2,486 Likes
St. Jude Donor '15
"In honor of jpee"
Well I have Headers and High flow cats.I also have 3" all the way back. You realy only feel a difference up top around 4500-5000 rpm. I also have heads and cam and am putting down around 330rwhp. So you have good potential to get 350 as my car has always dynoed low.
