Knock Knock !! Who's There ??
After golf last weekend the vette developed an off beat knock. The drive there was a bit spirited as i was running late, but nothing over 4500 rpm. Today i had time to have a bit of a look and listen. Couldn't really pinpoint the location, but it seemed a little louder on the pass side. Pulled the cover (love the egr delete) and found nothing. Ran it for a while with the cover off and still couldn't pinpoint it.
I'm going to have to bring the stethoscope from work and try again.
I hope it's not the start of a con rod bearing or wrist pin going south as i wasn't planning on any motor work till next winter.
Any thoughts
Any thoughts
St. Jude Donor '05-'06
Sounds like a plan to me hope it isn't what you think but it is the most likely source.On my car the pass side sounds a little noisier than the drivers but no knock(Knock on wood)yet.
Pull plug wires one at a time to see if you can locate which cylinder. That should also indicate rod or small end trouble if the noise goes away without combustion pressure.
When you say "off beat knock", do you mean it is not synchronous with engine speed? Does your '86 have pre-catalytic converters, and are they old...?
Don't jump to conclusions yet. I had an '86 which developed a knock which I feared was a rod bearing. Turned out to be a bad pre-cat.
It sounds like its comming from the rod area and is kind of off beat compared to rockers and injectors ticking. When i rev it the knock increases and when i let off, the knock decreases faster than the sound of the rpms. Almost like it floats when revved and settles down quickly under no load.
Originally Posted by AGENT 86
No cats
I hate to say it but it sounds like a rod bearing, did it get louder under load ?
Sorry to hear your havin some probs ..... I think you said you pulled valve cover, checked rockers, collapsed lifter, etc.?? , keep us posted Mick
sorry, but it does sound like a rod knock, however I would double check the valve train-has your oil pressure changed at all?
You might even want to drain the oil and see if any metal particals
appear-if not I might be inclined to go to the next heavier oil-just to see if it makes a difference.
Originally Posted by mseven
86,
Draing some oil may shed some light.
I had (may still have) a similar problem on my '91 L98.
I get an off beat knock like you are describing coming from the lower end off my engine if i take the car on a long run,usually starts after about an hour?
But only on a long run.
This car is my daily driver and ive never had this problem going to and from work every day,BUT now and again when sat at red lights etc the idle would drop right down-almost stall-then recover,when the revs got really low i got the same noise?(only happend on about 3 occasions though)
Last friday i had to go on a long run-got the "noise" on the way home but it did die on me a couple of times.next morning i couldnt start it without the engine dieing on me-no fault codes??
I changed the aic valve for a new one-havent had the problem since going to and from work,not been on a long run yet though.
The old aic valve was well sh**ted up,have give it a blast with carb cleaner in the past for quick fix.
why does a low idle cause this noise?? ony 63,000 miles on the clock and oil changed every 3 months
1 Post
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
Any thoughts
Any thoughts
The good news is it's almost time for the poor man's carport this year, and it sounds like you planned to do it anyway after next season..........
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Our Exploder was diagnosed with a loose flex plate that turned out to be a loose wrist pin that tore up the cylinder wall.
Well, weren't you thinking about a 383 anyways?
damn, i hate to hear any news like this dan, let's hope this turns out to be a benign situation.
I'm leaning towards 406-434.
Hey Tim, how about shootin me some info on your badazz combo
Originally Posted by Hot Rod 90
i thought that bad rod bearings normally are accompanied by a marked decrease in oil pressure. a loose wrist pin is beginning to sound like a possibility.
Time for a second mortgage
Don't let it self destruct. Right now it's got a lot of good parts so it's worth something. Let's pretend a rod lets go, now you have mostly jumk that can't be used to offset some of the expense of a new engine. Oh yeah, I've heard that cam bearings going bad can knock.
