Car sounds bad at startup
my L89 sounds like it has a knock at startup. but when it warms up it goes away and purrs like it is susposed to. it sounds like it is comming from the drivers side but I cannot say 100%
any ideas?
any ideas?
Received 3,043 Likes
St. Jude Donor '05
w/65Z01, could be a number of different things. Try the stethescope.
Originally Posted by Redeasysport
30lbs @ start up is LOW especially with fresh oil.
I donno where you should begin... I am worried about the pump, first and foremost.
My car sounds not as good on start up. You must be running rich in open loop. Open loop mode also uses a lot of gas. IMO, Once you're in Closed loop, the car will run and sound a lot better.
Originally Posted by CrazyInBlack
oil pressure gauge reads 30 at startup
it sounds like a knock now though
Have you ever overheated the engine? It may be a collapsed piston skirt. Symptoms are a rattle or knock on cold startup. Once it warms for a few minutes it goes away. The first Vortec truck engines had this problem. Not a big deal as long as you don't hammer it when it's cold.
here is my crazy guess and it depends on the year of the l98. my 85 has a knocking sound at start up especially when it is cold. turns out there is a pulsation in the fuel return line (passengers side). the knock goes away at the engine warms up and warms the return fuel. This was addressed in a tsb and recommended a part that I dont think is available.
