Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-30-2005, 12:36 PM   #1
85C4fanatic
CF Senior Member
85C4fanatic's Avatar
Default Info needed on 14011034 heads
I was given a set of these heads. Are they any good? Dont know much about them other than they have had a valve job and been ported. Can anyone chime in to if these are better than stock 85 heads?
85C4fanatic is offline   Reply With Quote
Old 08-30-2005, 04:10 PM   #2
q2blaster@work
CF Member
q2blaster@work's Avatar
Default Phase 2 Bowties
10134392 Phase 2 Cast Iron Bow Tie Head
The Phase 2 Bow Tie cylinder head (casting P/N 14011034) has the highest performance potential of any cast iron Chevrolet head. It is intended for off-highway applications only. Although the Phase 2 cast iron Bow Tie cylinder head has the same casting number (14011034) as the Phase 1 head it replaced, there are several significant differences between these two heavy-duty cylinder heads. The Phase 2 cast iron Bow Tie head can be identified by its redesigned outer water jacket wall with a machined bar between the exhaust manifold flanges. (Phase 1 castings have a raised parting line between the exhaust manifold flanges.) The area around the tapped water temperature sensor hole is also machined flat on the Phase 2 head. The Phase 2 Bow Tie head has a revised combustion chamber design with a true volume of 64cc's. The quench areas beneath the spark plugs are filled to increase compression in competition engines. The intake valve seats are machined for 2.02" diameter valves; the induction hardened exhaust valve seats are finished for 1.60" diameter valves. The intake and exhaust ports are identical in Phase 1 and Phase 2 cast iron Bow Tie heads. The 184cc intake runners will satisfy the airflow requirements of most competition engines while enhancing throttle response and mid-range torque. In unmodified form, the Phase 2 Bow Tie head will flow more air than any production cast iron small-block head. Extra-thick wall sections allow the ports to be enlarged to increase their flow capacity. The manifold heat riser passages are deleted in Phase 2 Bow Tie heads to produce a cool, dense intake charge.
Technical Notes: The valve spring pockets in cast iron Bow Tie heads are machined for up to 1.50" diameter competition valve springs. The rocker stud bosses are tapped for screw-in studs; studs and pushrod guideplates are not included. Use GM Performance Parts studs P/N 3973416 (3/8") or P/N 3921912 (7/16") and hardened pushrod guideplates P/N 3973418. Use 5/8" hex-head spark plugs with tapered seats and 3/8" reach. A bare casting weighs approximately 42 pounds. Valve seats are heat-treated.
I have them on my 85,w/comp cam, they work great, I think they have great potential once the stock tpi is dealt with
q2blaster@work is offline   Reply With Quote
Old 08-30-2005, 04:24 PM   #3
85C4fanatic
CF Senior Member
Thats great to know. I guess I'll plan on using them. Did they work with the original system. (ie intakes) The prior owner already has put an aftermarket cam in and headers so I figure next is to let it breathe to take advantage of the other mods. What intake setup did you use with yours. i was thinking AS&M long tubes with an accel base. Any suggestions are appreciated.
q2balster for the info.
Old 08-30-2005, 05:03 PM   #4
q2blaster@work
CF Member
Everything bolted up ok, only problem was I had to remove the heat sheilds from the exhaust manifolds due to spark plugs hitting, with stock plug wires they will clear the headers w/shields removed, but my msd wires hit and burnt so Im sticking with stock wires until I put decent headers on.
Old 08-30-2005, 05:18 PM   #5
85C4fanatic
CF Senior Member
When did they start making the phase two heads? I want to try to see if these are an original set or phase 2 set.
Old 08-30-2005, 05:30 PM   #6
q2blaster@work
CF Member
Old 08-31-2005, 10:49 AM   #7
85C4fanatic
CF Senior Member
Well it looks like I have an original phase 1 set of heads So I guess these arent as good as the phase 2 set correct?
Old 08-31-2005, 01:33 PM   #8
q2blaster@work
CF Member
I think the biggest change was the combustion chamber design, I wouldnt htink theres 15hp difference bewtween them if that.
Reload this Page Info needed on 14011034 heads
Tags
14011034, block, bowtie, cam, casting, chevrolet, chevy, dyno, flow, head, heads, numbers, phase, review, run, small
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
