Anyone using carbon fiber body panels on the street?
Hi everyone,
Just curious if anyone is using carbon fiber body panels on their street car?
The reason I ask is 'cause I was checking out the Exotic Muscle website the other day, and was going through all their carbon fiber body parts for C4s (hoods, doors, rear quarters, etc...). Great looking stuff, but a large majority was labelled "Race Only". I don't know if that's for liability reasons, or because the carbon fiber stuff poses some kind of problem for daily use. Anyone know?
And for those that are running carbon body pieces, do you notice a true SOTP difference due to the reduced weight?
Thanks in advance.
Thanks in advance.
Originally Posted by TheCorvetteKid
Hi everyone,
Thanks in advance.
Thanks in advance.
I agree with Zix.
BTW, The biggest SOTP improvement from weight loss comes
by reducing mass from the fastest moving components. Start
at the engine and work your way out to the wheels.
To generalize, chopping 10lbs from reciprocating mass in the
engine has roughly the same performance impact as does dropping
150lbs of weight from the chassis, body, interior & ect.
Originally Posted by Slalom4me
To generalize, chopping 10lbs from reciprocating mass in the engine has roughly the same performance impact as does dropping 150lbs of weight from the chassis, body, interior & etc...
OK, I know this is off topic but where would you start to remove this 10lbs. of reciprocating mass on an '89 L98 (6-speed)?
Looks like I over-generalized in what was intended to be a simple
example. How about if I amended the post to read 'reciprocating
and rotating mass in the engine'?
Then we could sum up the frisbee, pulleys, harmonic balancer,
flywheel, clutch & so on, along with the Ti rods and ditch much
more than 10lbs.
If using such parts seems impractical, do up a budget for what
the REAL cost of changing over to carbon fibre body parts is
and then compare the cost/benefit against swapping to lighter
engine parts. Consider maintenance over time, too, to arrive
at a true impact on Total Cost of Ownership.
Or do you take issue with the part about how losing 10lbs recip/rotat
at engine speed has an impact on acceleration that is more or less
equivalent to losing 150lbs off the chassis & other non-recip/rotat
components of the vehicle?
along with an ex nextel cup lightened billet crank, casidium coated titanium wrist pins, wiseco shape 5 pistons, aluminum flywheel, 7.25in 3 disc clutch, aluminum ati balancer, carbon driveshafts. That should about do it. It will rev like a GSXR, and with proper valve train/heads will scream right to 9k. Beats a carbon fiber body everytime.
Or do you take issue with the part about how losing 10lbs recip/rotat at engine speed has an impact on acceleration that is more or less equivalent to losing 150lbs off the chassis & other non-recip/rotat components of the vehicle?
Something like titanium con rods is not something I'm prepared to do right now, and the clutch and dual-mass flywheel (stock) on my car are only a couple of years old with probably 10,000kms on them so they have alot of life left in 'em. I have already removed the frisbee from the front of the engine in the quest for weight reduction, and the the lightweight balancer and pullies you mentioned are something that I have been considering for some time now. Any recommendations for either one?
As I mentioned above, I'm not ready to break into the bottom end of the engine as of yet. But the carbon fiber driver shafts sound intriguing - who makes 'em? Any idea on price?
And an aluminum balancer? Really? I didn't know anyone made aluminum balancers. I'm gonna check it out - thanks!
This thread may be heading off topic, but I don't care - this is GREAT stuff!!!
Received 1,401 Likes
Denny's makes the CF shafts.
Do not expect power gains from going to them, their benefit is strength. Their inertial moment is actually slightly higher than the stock shafts, so they cost power, albeit a negligible amount.
Only if you can find someone who makes lighter and smaller shafts would you be guaranteed of gaining anything back.
Weight Reduction
I have participated in several weight reduction threads during the past year and actually one of the best weight reductions can be lighter weight wheels and tires.
You asked about CF parts...I am in the process of cutting weight out of my 1984. My goal is to get it down to 2800 lbs. I have purchased a carbon fiber hood, lexan rear window, a melrose roof skin, added aluminum heads, light weight intake, light weight starter, light weight water pump, removed the heavy factory carpeting and lots of other stuff. I still have a ways to go but I am sure I can get it down to 2800 lbs or less with some continued tweaking.
While many will tell you to make your power in the engine and not worry about weight of your car and that is fine...however if your car is lighter it will be MUCH easier on parts. Most of the guys breaking their Dana 36's are making some solid horsepower in a fairly heavy cars. Nothing to get hung up on but it is certainly worth considering.
Originally Posted by NitrousSam
...one of the best weight reductions can be lighter weight wheels and tires.
Wheels
Excellent suggestion! Any recommendations?
My goal is mainly drag style racing so for me Bogart or Weld wheels tend to be the better choice. The Aluma Star by Weld are great ones http://www.weldracing.com/Weld_Motor...k/15alum2.shtm, the Magnums are also very nice from Weld http://www.weldracing.com/Weld_Motor.../15m1pcBO.shtm. I like the look of the Aluma Lights http://www.bogartracingwheels.com/wheels/alumalight.jpg
Originally Posted by montie98
Why not just ride a motorcycle?
and a '03 OEM Z/06 Speedline wheel (17x9.5). That's a reduction
of 32 lbs per set. (52 lbs vs 44 lbs with the same 275/40-17
Goodyear GS-C tire mounted.)
The benefit from reducing chassis rotating inertia is not as great as
that from reducing engine RI. Still, if you removed a 12" dia disk
that weighed 8 lbs from a wheel hub, this would have three times
the benefit of removing a jack and lug nut wrench weighing 8 lbs.
Rev like a GSX-R and scream to 9000rpm!!! BOY, do I like the sound of that!!! I realize you're probably exagerating just a little, but it still sounds cool.
QUOTE]
nope not at all, in fact it's commonplace in Nextel cup cars. they turn 9000+ for 500 miles. 4.125" bore, 3.34(?) stroke, they are very over square and like I said with the proper valvetrain, Such as a good used set of "short track" Sb2 heads/intake makes for one Badss small block. By anyone's standard. Ask Jeb, I believe he went Sb2 recently.
QUOTE]
There is roughly an 8 lb difference between an '89 wheel w/ cap
This is a GREAT discussion!
The car is mainly a street vehicle, but any racing would be strictly road racing.
I will admit, I like the idea of a set of '03 Z06 wheels. But I'm sure there are other street/road racing wheels which would be even lighter. Any suggestions?
Sure I have lots of recommendations but before we get into them I would need to know what purpose you would be using the car for. Drag racing or Road Racing? It makes a HUGE difference which ones I would recommend.
What's Your budget?
What is your budget for wheels?
Let's say, up to $4,000 (give or take $500) not including rubber.
