Need help with 2 grounds driver rear (Pics)
I am having trouble locating where these two ground wires connect and help would be appreciate. My car is a 92 coupe. Below are the pictures of the grounds:
Ground 1
Ground 2
Ground 1
Ground 2
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'd hook them to a ground! Just kidding. I'm having trouble telling exactly what part of the car the first pic is. The second one looks like it could be one of the antenna grounds.
Originally Posted by mothersworry
The first picture is the Drivers side rear where the body meets the bumper fascia. Hope this helps.
I see now how they go. Corvette Kid you are right These ground at the antenna bracket and then the antenna and bracket assembly is groundd to the frame. Thanks for all your help.
I see now how they go. Corvette Kid you are right These ground at the antenna bracket and then the antenna and bracket assembly is grounded to the frame. Thanks for all your help.
On my 86, there is a "tortion" bar that goes accross the back, just forward of the fuel tank (2-3"). This is a solid bar. (Not the one mounted onto the rear dif. cover). It is bolted on either side with two bolts, one front and one back. My grounds are mounted on the back bolts.
Hope that helps.
Fred
Hope that helps.
Fred
