Corvette complete independent rear suspension Dimensions?
I did a search prior to posting this thread. I was hoping to find it and if it exists, some please tell me so that this thread can fall to the bottom of the page.
It seems as though the Vette IRS subframe makes an excellent swap for kit-cars/replicars/upgrade for people wanting great handling and as C4 parts are generally less expensive than C5 parts, I think it best to start searching out dimensions on the C4.
From disk to disk, just how long is the subframe?
From the most extreme point in the front to the rear, just how long is it?
From the most bottom point to the most top point, just how long is it?
Is the C4 subframe appreciably different than the C5? I'd like to go as new as possible at the best price and I would like to make sure the subframe fits the dimensions of the swap.
thanks to everyone for their help.
Originally Posted by scourge
The measurements aren't common knowledge?
Is the C4 subframe appreciably different than the C5?", and that includes tearing it down to totally re-bush it, or change the wheel bearings, or to change all 6 u joints.
To answer your question, "The measurements aren't common knowledge? "...NO! Not to any Corvette owner, and why would/should they be?
RACE ON!!!
RACE ON!!!
Well, this is the TECH/PERFORMANCE Forum, so it makes sense to think that poeple who post here are quite familar with the TECH/PERFORMANCE aspects of the C4. If I am wrong then I will have to look elsewhere but it seemed logical to ask Vette guys in a tech forum about their cars just as it is reasonable to assume that perhaps some Vette owner has wanted to swap a C5 subframe onto a C4.
One doesn't know without asking. I'm not clairvoyant.
There is no subframe. As stated above you'll probably find more useful info on a forum for people who use vette parts to build rods rather than a corvette forum.
Not saying you aren't welcome! Just offering advice.
RACE ON!!!
RACE ON!!!
My daily driver doesn't have 50 years of history with hundreds of thousands of dedicated enthusiasts that east/sleep/breathe my car at a site dedicated to it with a forum existing for performance. So, your sensitive tiff is silly. You don't know and that's fine but this thing called the Internet is actually worldwide and on 24 hours a day 365 days a year.
It is quite possible and reasonable to assume that some point in time some Vette enthusiast would have looked and measured. I didn't come here to start any animosity so please take a chill pill dude.
plus, I found this on EBAY:
Complete C4 IRS
Will ask the owner if he knows.
Complete C4 IRS
As for the measurements this is a C4 tech forum and no one really needs to know, what those measurement are when they are swapping D36s for D44s etc since they know it is a basic bolt in.
As others have already stated there is no sub frame
I think the pushback you are getting is due to your condescending nature of your secondary posts.
Since the C5 is a rear transaxle car most C4 guys have not considered a rear end swap. However, since the internet is on 24/7/365 you already knew that.
The front to rear length of the C4 differential is different between the D44 and a D36. The rotor to rotor widths are the same. The best thing to do is to call the seller and find out whether it is a D36 or a D44 and see if he/she will take the measurements for you. If it is a D36 and you are looking at a high horsepower manual tranmission project, I would pass and look for the Dana 44.
Good luck
Mike
Mike
I wasn't condescending.
Why is it so often that when a noob posts to ask a question and a regular poster is actually the one being condescending that all the other posters immediately and automatically jump on the regular's side?
This IS a tech forum populated by mroe than just one guy and this is why I posted here. Not condescending, just saying why I posted here. Sometimes it takes days to get a response but one can always hope to get one faster.
It seems that no one here really has to worry about the dimensions so its not something to know. This has been mentioned by others so its not an insult by me. I guess I will have to go to Hot Rodders forums to get the dimensions but it was logical to go to a Corvette board and ask here first.
Go to a used car lot and measure one yourself. Maybe for a 20 spot they'll jack the car up and pull the wheels off for you.
Originally Posted by artvette
No you're not. Just an irritant.
Isn't that measurement different between 84-87 and 88-96 cars?
It is quite possible and reasonable to assume that some point in time some Vette enthusiast would have looked and measured..
Originally Posted by CFI-EFI
I'm not saying that the information you seek isn't available here, but you act like we are all a bunch of dummies because we don't know information we have no cause or need to know.
RACE ON!!!
World is full of *******s and I see you're desperately trying to fit in...and succeeding.
RACE ON!!!
Mike
you expect me to know more about my car, and act as though I'm some sort of dummy, because I don't, than you do about your car.
aboatguy (Mike) , thanks for the reasoned reply. To get the answer, it may take a few weeks and that's fine. When one looks for information, its important to have patience and be open to all the possibilities/problems that are likely to arise.
My daily driver doesn't have 50 years of history ..
I found this link for you : http://www.hpsalvage.com/
And under specification (84-87)vette :
All aluminum independent rear with positrac
drum parking brakes incorporated into rear rotors
11 1/2" rotors Single piston aluminum calipers
Fiberglass leaf spring
Ratios 2.59, 2.79, 3.07
2 Models 36(7.875" ring gear) 44(8.5" ring gear)
Model 36 was used behind automatics
Model 44 behind manual transmissions
62" wide hub to hub with discs on
37 1/4" between batwing mounting bolts
44 1/2" between trailing arm mounting bracket bolts
Good luck with your project
Ps could you now tell us your daily driver?
scourge - I have a D44 out on the bench at the shop - I would be happy to measure it for you if you like....
I also have a D36 for sale if your interested - and.... I can ship it if needed
