LT1 balancer spun itself off the crank
Hub cracked, spun, backed the bolt out and walked itself right off the crank. Damn I have some bad luck
You can do what I did and get a keyed hub and that should never happen again. I know More sells them and i think Thunder may as well just be sure to get the corvette hub as the impalla hub is diferent.
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
the balancer was teh only thing still GM besides to block and head castings on that motor
1. If you have a keyless hub, how will a hub with a keyway make any difference (since by definition and IMO the crank is not keyed with a keyless hub)
2. What's the history of this? I have a 92 LT1 with a '383 and the crank is keyed, and I have a keyed hub which looks original.
Thanks!
if you have a keyed hub it IS NOT original
If you're using the stock crank you'll need to pull the crank timing chain gear off, remove the stock key and put in a full key. The stock crank has a notched key installed, so your new keyed hub isn't going to engage with anything....
