Cam question/problem
The car is back from getting a pressure line for the power steering pump put in. I am still having issues with the new cam. She will idle fairly well in neutral. If you are sitting at a red light in drive she wants to bog down though. She runs fine under normal exceleration but when you go to wot she wants to bog down again. All I can think is that I do not have the lifters set correctly. Any other thoughts would be great. BTW, 96 Lt1 and the cam specs are really close to the hot cam. they are Dur. @ .050 224 230 lobe sep:112. Thanks in advance
Originally Posted by Zix
You mean the rockers might not be set correctly? It's certainly possible, and something you should check. Also who reprogrammed your computer? Did you change anything else when you installed the cam?
anyway did you replace the stock converter with a 2500 or higher stall?
Originally Posted by ar91c4
hey I have the same cam but it has 110* lode sep..who makes the one you have?Mine is a comp x-treme energy cam.
Mine is a comp x-treme energy cam as well. I will be changing out the stall converter later this summer, stock for now. Did you have any of these issuses with your cam as well? I am wondering if it just needs some more miles on it to be broken in better?
In my opinion, if you just changed the cam then there really is no "break in" period...it should run right out of the box. So are you still running the stock computer programming?
No, they say there is a break in period for them. Comp Cams even gives directions on what to do. I am still running the stock program as of right now. BTW, I see you have a CE, I love those.
You definatly need to get the computer reprogrammed. The computer can "learn"...but I don't think it can adjust itself that much to run your new cam without some help. I'm getting my computer back from Ed Wright in a couple days...he's done most of my reporgramming and does a good job of it. Feel free to contact him at www.fastchip.com.
Originally Posted by TankerVette
interesting. I am having the same inexplicable problems. Is it the cam? (see sig)
GlockLT4, I am positive. Spent last weekend taking the front end apart to check it... Once I lined up the dots, I actually spent a half hour just staring at the gears to make sure it was right...
(I was really hoping that this was the problem!!)
Yes, I believe its the exact same cam.
CCA-07-503-8 Camshaft, Hydraulic Roller Tappet, Advertised Duration 276/281, Lift .503/.510, Chevy LT1/LT4
I stuck it in last october along with the heads. Drivablility seemed okay until I added longtubes in February. Seems real low on power, rough idle, occasional pop on tip in.
Really annoying.
Replaced Opti (twice),O2 sensors, tested everything, checked everything out, same symptoms.
Gonna try again with a tune soon, but it sure is frustrating...
Really annoying.
Really annoying.
Really annoying.
Yep, we have the same one. I will be getting a tune really soon I hope. Yeah it is a PITA when they don't want to run right. Good luck and if I think of something I will let you know.
Ok good, cuz i found out today that mine was off for oa year and 4 months
ar91c4-I am begining to suspect this also. bigger torque converter...
