Sway Bar End Link Install Question
Rear Sway Bar End Link Install Question
I bought a kit from a fellow forum member a while back and did not get any instructions.
Are you supposed to reuse the metal sleeves from the original rubber bushings when installing polyurethane end link bushings?
The rear links fit without the sleeves although it appears that the bar would eat through the polyurethane bushing without a metal sleeve in no time.
Confused because energy suspensions site indicates to reuse metal parts. Any help would be appreciated.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I reused the metal sleeves in front, but not in rear.
There's no way in hell they would fit. I put them directly into the sway bar. No problems so far, its been two years.
