Engine buildup pics
Old 05-23-2005, 11:34 PM
350ws6
350ws6's Avatar
Default Engine buildup pics
bolted most of the engine up today. Its a 350 so no assembly pics, you've seen them a million times before anyway...The machine shop is so backed up, so my forged 383 is nowhere close to being done (has to be bored, notched, decked, balanced etc by them) so for now I just built up the stock shortblock as much as possible
-Stock rotating assembly
-ARP main bolts and L-19 Rod Bolts
-Melling HV55 high pressure pump
-Canton 7qt pan w/ windage screen and crank scraper
-GMPP fastburn heads,210cc Intake,62cc chambers
-SFI spec balancer, double roller chain
-Tiny 214/224cam,to keep hp peak low so not to over rev the stock bottom end
-Headman headers
-On this motor will be the dual plane EFI mercrusier intake, the built engine will get the single plane converted to EFI
-Homemade DFI with wideband,255lph pump and aeromotive reg
and the dyno predicted runs
Old 05-23-2005, 11:43 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Lookin good! Should be quite a street terror
Old 05-24-2005, 12:09 AM
AGENT 86
AGENT 86's Avatar
Like the look of those heads and the single plane
Old 05-24-2005, 11:02 AM
oldace84
oldace84's Avatar
St. Jude Donor '04 & '05
Just a plain "WOW".
Good Luck
And thanks for the pic's.
Old 05-24-2005, 09:11 PM
NitrousSam
Support Corvetteforum!
NitrousSam's Avatar
Intake question: Will you have to machine the top of the intake down at all to get it to fit under your hood?
Old 05-24-2005, 09:17 PM
ar91c4
ar91c4's Avatar
so if everything needs to be done yet(boring,honing,balancing,)why did you bolt the heads on?
Old 05-24-2005, 11:46 PM
350ws6
350ws6's Avatar
I am reusing the stock shortblock for this summer, If i waited until my new shortblock was done it would be fall. This winter I'll transfer everything over to the new block.
To Engine buildup pics
Quick Reply: Engine buildup pics
