Evidence of blown head gasket, but car running great –any experts around?
Here is a link to a vender that sells the block tester. This one works off of enginge vacuum. There is another type that that uses a rubber ball hand style pump to draw the vapors into the tube.
http://www.tooldesk.com/products/default.aspx+sid+266
Originally Posted by rick lambert
Incidentally, if you do a compression test, all cylinders should read within 10%-two weak
ones, especially next to each other means Blown gasket or cracked head probably as high as 95% of the time-sorry.
Originally Posted by Stingraynut
The info on the gaskets is very handy, I will order all the necessary parts first.
I think that when they recondition the heads they also replace the valve guides and lap in the valves? is that right/normal?
Originally Posted by MtlSphere
But be aware that milling the heads requires milling the intake by the same amount to keep the mating surfaces inline.
The pressure check on the rad with a warm engine is a good place to start - I'll organise that next week. If I get extra pressure on revs ? then I'll try the block tester, if I can locate one, and go from there.
One thing to bear in mind, is that anything you decide to "add on" to the operation, basically has the labor "prepaid". Be sure, however, to establish that point with the shop before you ASSUME anything. Good luck, and...
RACE ON!!!
Thanks CFI-EFI, appreciate your advice, all very useful.
As for me getting parts, I do check with workshops first but in the case of the vette and living in Australia, some parts aren't available here and have to be shipped from the US, so every workshop so far has welcomed me doing all the ordering. That's part of the reason I try to research each job as much as possible, find out what I can expect to be done and so on.
I had my coolant tested today at the radiator shop, they had the vacuum bottle and fluid similar to that mentioned on the forum.
NO indications of CO in the coolant - we tested it very thoroughly at idle and then again holding 2300rpms for about 2 minutes.
The workshop added a grey powder called 'Seal leak' to the coolant when they discovered the possible blown headgasket It's also recommended to be used when fitting new head gaskets as it stops the glycol from penetrating anywhere before the gasket beds down.It doesn't clog the radiator, only sets when exposed to air. (and there was about a level teaspoon of the stuff)
I wish I'd tested it before they put the stuff in - I really believe it would still have tested negative.
I suppose this buys me some time - if it wasn't for them saying coolant gushed out of a hose , I'd say there was nothing wrong.
Rob
Rob
