CR with SR and 219?
Old 05-15-2005, 07:34 PM
JUAN J SANCHEZ
JUAN J SANCHEZ's Avatar
Default CR with SR and 219?
What compression ratio's are you guys running with a 406 SR219 combo? I've got one I'm currently building and I'm going close to 11.0:1 (10.8:1 w/.044" quench) according to intake closing point I'm right at the edge of pump gas! It's got 195 cc AFR Heads.
Old 05-15-2005, 09:00 PM
Caboboy
Caboboy's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
I think you're fine Juan, I'm at 10.66 with the same combo in a 421 and my octane out here is 91. I think the big thing is to determine if it's a true LPE or one of the knockoff versions which have a 4* advance. My cam is an Erson small base circle which came with the advance, so I had to retard it 4* to regain the true LPE valve events. That did wonders for my dynamic CR. I'm amazed at the idle quality...........it sounds like a stocker almost. Just be sure you install it at 112* and you'll be fine
Edit: My quench is fairly tight at .040
Old 05-15-2005, 09:36 PM
Corvette0096
Corvette0096's Avatar
Not that I have a 406 But my 381 has 10.75-1 and I have taken out a head gasket to detination. I now add Av gas to be safe. All's it takes is one bad tank of gas.
Old 05-15-2005, 09:42 PM
J Z06
J Z06's Avatar
My 383 219 combo was 11:1 and like Rich, I had detonation a time or two.
Av gas Rich? That is for higher altitude burning I thought? A little 116 now n then would be fine...but it should be ok for pump gas.
Old 05-15-2005, 09:47 PM
Corvette0096
[QUOTE=Jay 383]My 383 219 combo was 11:1 and like Rich, I had detonation a time or two.
Av gas Rich? QUOTE]
Yah then I throw some more fuel in it on the PE tables..I think I will get some race fuel to be safe..
Old 05-15-2005, 10:55 PM
JUAN J SANCHEZ
Thanks for the replies guys! I'll look into the 4 degree advance on the cam. Thanks again!
To CR with SR and 219?
Quick Reply: CR with SR and 219?
