Is using zip ties bad for plug wires?
I recently changed my plug wires and broke most of the wire seperaters or what every there called is there a problem with using zip ties or could this cause problems?
The wire seperators broke because they got brittle from heat & age, zip ties will not last 1/4 as long as wire seperators.
The best wire seperators I have found are the blue Moroso brand, I've had them for going on 15 years now and they show no signs of weakening.
Location: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Plus you need to keep the wires separated to avoid arc burns in the insulation.
I've checked all the auto parts shops and nobody carries wire seperators that will mount in the place as the stock ones. I found them at ecklers but there 4.99 each
Received 1,404 Likes
Ive used zip ties on the pass. side for about 2 years now with no problem.
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
There are quality differences in zips like anything else. You can get some that will take much more temperature than others. I use them in a couple of places with my headers. I also use some Moroso separaters.
Here's a tip....don't just zip them all together in a bunch. Put one zip tie around all the wires, then use three more (for 4 wires) around the first one (perpendicular to it) between each wire pair. Gradually tighten them up and you'll end up with a nice flat tight wire holder. I can send you a picture if you aren't sure what I mean.
Here's a little text image, I hope it looks Ok. Paste it in Notepad with a monospaced font like Courier New.
W W W W
W W W W
WZWZWZW
ZZZZZZZZZ
WZWZWZW
W W W W
W W W W
Originally Posted by Atok
We have had ZIP ties on our oval track race car for a few years now, extreme heat, no problems at all.
W W W W
W W W W
WZWZWZW
ZZZZZZZZZ
WZWZWZW
W W W W
W W W W
W W W W
W W W W
WZWZWZW
ZZZZZZZZZ
WZWZWZW
W W W W
W W W W
Thanks for the responses. The zip ties I used should be fine, I've used them before in other places in the engine compartment and haven't had any problems
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
IMHO If zip ties are used, do not pull them tight. Too tight will compromise the insulation and may cause for a short to ground. Snug enough to hold the wire in place is fine.
BTW, factory replacement clips are available from Corvette Central at reasonable prices.
1 Post
You may want to check out theses guys for wire looms - Made For You Products.
http://www.madeforyouproducts.com/
www.stormfront.org
www.davidduke.com
www.natall.com
www.nationalvanguard.org
WHITE PRIDE WORLD WIDE!!!!
www.davidduke.com
www.natall.com
should not be a problem.....try Summit, Jegs,.....you might need to mod a little......
http://www.taylorvertex.com/hp/Clamp...eparators.aspx
I bought some separators, removed the factory separators from the mounting bracket, and then mounted the new separators to the factory mounting brackets....modded them slightly & used a machine screw to attach separators to the factory brackets...
ty wraps can work, but do not cinch them real tight or you will damage wire insulation
Good luck.
