Where to buy new fuel lines?
Forward fuel lines have been discontinued (at least on my 90), you will most likely have to make them. Accel makes a kit to plumb into the saginaw fittings on the end of the fuel rail.
Doug
Doug
Originally Posted by 8835thL98
Where can I buy new fuel lines for my '88? I need the passenger side one that screws into the fuel rail. Any help?
I've saving this project for last.
does anyone have a link for the accel kit?
www.mrgasket.com
Then click on the DFI links from there. They have a complete catalog that you can download of all the DFI products.
Doug
Doug
I'm not sure about that kit. As I havent used it( I couldnt even find it on the site).
You can use brake line tubing. That is what I did. Just make sure you get a good bender. I have a RIGID #456. You can get it at Home Depot. I used the brake line from AutoZone & custom bent it & sprayed it with rust-o-leum<sp? & ofcourse double flaired the ends. Pressurized it up & have no problems.
I only replaced what needed to be replaced which is about 15 ft of line. It cost a total of about $50, IIRC.
can you send me the link for that kit? and how much does it cost?
Doug
One other way you might go is to buy the line from someone parting out one of these cars. I was able to pick up the complete fuel lines(including return) from the filter to the fuel rail in excellent condition for under $50.
I was referred to a company through another member here, I am going to pull mine and send em in for repair/replacement whichever is more feasible. The price seems very reasonable, after I get them back and can see their work I will pass on their info. Dont want to refer until I am satisfied, then I know others will be.
Are there any supporting vendors that specilize in hydraulic lines?
Doug
Doug
Doug
The passenger side fuel line that attatches to the fuel rail is the one i need. The nut is stripped and won't screw back into the rail. I've tried using a file and that didnt do anything either, so are all the above parts necessary for what i need in order to replace it? I'm sure someone has had this similar problem before.
I understand that it is a crapshoot, mine came from "corvettesalvageyard" and were mint. They were also shipped in a long package to keep them in good condition.
You got a link or something for them? I may need it if my lines disappear in shipping!
Doug
does the passenger line connect to the fuel filter or does it go all the way back to the tank?
Tom Melton
82 CE
86 Z51 Coupe
Sorry for the delay, here is a link to the auction that has a good picture of what I'm talking about.
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMERFB%3AIID
