ZR1 dash swap
ZR1 dash swap
My tach doesn't go high enough (1990) with the new engine. Is swapping in the dash stuff from a ZR1 pretty straightforward? Are there any "traps"?
I believe the only choices in a Tach are the 6500 RPM standard, and the 8000 RPM ZR1 tach.
Lingenfelter has offered to change over to the 8000 RPM tach for several years, but it is a "send the dash to them" mod.
Only other difference in guages is the oil temp guage, which is different also on the ZR1.
90-91 Will swap with your 90.. 92-96 will not unless youchaneg the LCD and rewire a couple of the Warning lights..
Also as far as i know the 94-95 ZR-1 dash and 96 LT4 dash used the same part number
thanks guys
