86' vette emissions tube on the cat?
what will be affected if the emissions tube that runs to the catlytic converter is disconnected? i have an 86' that i am having tuned ( forgot to tell the tuner that it was disconnected ) any help will be great
Received 1,404 Likes
It wont hurt a thing.
Originally Posted by REDC4CORVETTE
Been there done that .
NOTHING!
NOTHING!
I would love to get rid of that piece running from the cat to the engine compartment. It ratles, and gets in the way when ever I have the exhaust off to do anything. And on my 86, I have to take the exhaust off anytime I do anything exept maybe change the oil in the headlight
Air is diverted to the Cat once it's warmed up, so you will get noise (much like an exhaust leak) unless you eliminate the pump or hook up the hose. There is also a check valve on the Cat line. This prevents exhaust from flowing back towards the pump. If you eliminate the line, you need to plug the Cat fitting.
i just read in a haynes manual that the exhaust gas recirculation system cools down combustion chamber tempatures ,and if you disconnect the hose from the cat it is possible that the engine could idle differently. right now i do not have my hose on and i am flashing a code 32. my engine is also idleing a little rough even though i have a custom cam i dont think it is the cam. now the question is where does the other end of the hose go? i cannot find the other end because i wasnt the one to take it off. anyone experience this? any help or suggestions would be appreatiated
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I pulled the center cat off my 86 and left the air pump tude hanging out in the engine compartment. Has not effected idle, running tune nor WOT performance.
