How to Remove the drain/fill bolts on a 6sp?
I'd like to change the oil in my trans (94 6spd). There are two Hex type (allen bolts) and I can't seem ot find a allen to fit. The guy at the auto parts store said there is a tool but its a dealer item. I was wondering if any of you folk have come up with a way of removing this with out the tool. I was thinking about using a bolt with 2 nuts jamed down, so I can get a socket on it. I think it's 17mm.
It's not a dealer item... What BS. You need to do one of two things: find a bolt with a 17mm head and lock a pair of nuts on it (cheap), or find a real hardware/tool shop. I bought mine from a place called Tacoma Screw. Be prepared to drop at least $20.
It is not a dealer item, your plan for using a 17mm bolt will work fine, otherwise just find a real hardware supply store and they should a 17mm 1/2" drive allen socket. They are about $20.
St. Jude Donor '10-'11-'12-'13
Autozone has a set with a 17mm hex 1/2" drive for $8. It works great. Remove the fill first so you're not stuck with an empty transmission if you can't get it out later.
Go ahead and order new plugs
Jimijoe, I had trouble with the transmission filler and drain plugs in my 1990 six-speed. I tried an Allen wrench (17mm) and a 17 mm hex socket. I used a breaker bar and a floor jack, and still got nothing accomplished. Finally, I took it to a Corvette repair shop in Richmond, Virginia, and they applied heat and removed the plugs.
I ordered new plugs because a previous owner had pretty much ruined the drain plug. -- Eric
Hi All;
Thanks for the advise; I didn't realize the drain plugs would be that tight. I thought I read the torque spec was 25ft lbs, so I figured getting them out would be a breeze. I will definately purchase a 17mm Hex bit and NOT take a chance with a home made adapter. I'll also try a lil heat.
Thanks again
Thanks again
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
I welded a 17mm nut on the end of a short 3/8" extension.
Looks trick and works perfectly.
PS The tightening torque is 25ft lbs, but it takes three times that to break them loose!!
Larry
code5coupe
Larry
code5coupe
I'm sure some guys will disagree, but I put yellow (oil resistant) teflon tape on mine when I put it back together. I have done it without the tape & got leaks.
It'll mess up the tq spec but it won't leak. Use you judgement on the tightness.
I ran my '91 for about ten miles before I attempted the plugs and they came right out. I used plumbers "pipe dope" when I replaced them because they have pipe type threads. Not one problem. The heat made the difference
Woohoo! Score one for "search"! I can't get my fill plug off (thankfully I'm no longer dumb enough to pull the drain plug first, only to find I can't refill it) and was going to try heat from a plumbers torch. I was a bit worried that this might be a bad idea, but sounds like you all have had success! So wish me luck!
My suggestion is the same as others have said. Get a proper 17mm allen socket because if they have never been out before they are hellish tight. Remove the fill plug first. When you re-install the plugs don't torque them to 25 lbs-ft (factory spec). I don't go over 15 to 20 lbs-ft which makes them come out much easier the next time. Don't worry about them coming out, after the first heat cycle they'll seize in there nice and snug.
