TB / IAC Cleaning - DISASSEMBLY (PICS)
Hey guys, quick question, I am in the middle of this project but have hit a roadblock, was hoping to get her done tonight so hopefully someone can help.
I am trying to disassemble my TB and IAC so that I can clean and service them. I have everything taken apart except the two coolant lines that have the screw-type fasteners on them. I tried loosening the screws and then took the screws out completely, but can't get the coolant lines off.
Am I missing something? I just don't want to damage the lines or break something. It's the one on the passenger side down near the IAC, and at the front, below the TB
Pictures attached.
TIA for the suggestions.
Pictures attached.
this is a good time to bypass that cut it and go get new hose and connect both ends thats not on the TB and be done with it.
BTW i just cleaned my TB and IAC alittle while ago. took me about 45 mins total
if you want to save it pull the last bolts out of the TB and pull the TB and angle it so you can fit a flat head screw driver between the rubber and the TB flange and try to wedge it off but you should just bypass it and get new hose clamps anyway.
Hmmmmm....
Okay, got all 4 bolts out, but zero movement from the TB, and still not able to get the coolant lines off. I would like to bypass as suggested above, but need more info about cold weather imapct????
Also, how do I disconnect the throttle linkage???
Sorry for the silly questions guys. I am still learning the technical side.
Originally Posted by TerryMathews
Hmmm, I don't know. TB Bypass in Alberta, Canada? If you do it, you're not supposed to drive below freezing (as I understand it).
Good luck!!
Oh, and I opted not to do the bypass either at that time. I might do it this summer as my car only goes out when the weather is warm.
Once again good luck.
Originally Posted by smack123
Hmmmmm....
Once you've gotten the 4 bolts out, you should be able to remove the TB. It's probably stuck on the gasket (hoped you picked up a new one), just give it a little tug.
Make sure you clean the mating surfaces of the TB and plenum before you install the new gasket as well.
Once again, good luck!
I've done it yesterday. Those clamps are designed so they don't automatically loosen just because you remove the bolt. You must get a flat head screw driver between the hose and the flat piece the bolt was pushing against. Turn to pry that flat piece up and away from hose. It will come loose!
Rotate the clamps on the hose to be sure they're broken loose. And don't expect to get the clamps to come off over the hump in the nipple with the hose. Push them toward the TB and off of the hose before pulling/prying hose away from TB.
One linkage has a retainer clip while the other has a little swaged peg on it. Run your fingers along the cable toward the swaged end, pulling the cable out of its guide slot so you can rotate the peg until the cable slips sideways out of the guide plate. You end up with the cable coming out of the peg pointed toward the front of the car, just before it can slip sideways.
Hmmmmm....
As for the throttle linkage, there are little clips that need to be pryed off to release the cables. You use a small flat blade screw driver to pry off the clips. MAKE SURE you keep one hand on the clip at all times as you pry it off. The clips are called "Jesus clips" because if you do not have a hand on them when you pry them loose they will fly off into the engine bay causing you to say "Jesus! Where did that go!"
HTH!
YES, the TB/IAC is off!!!!!! Thanks to everyone for the great tips and suggestions!!!!!
Don't worry MikeC4, I knew I still had that bolt to come off (step#1), it's all good.
I'm picking up new gaskets tomorrow.
1. Now, how do I remove the pindle from the IAC?
2. The plenum is also very carboned, should I remove it and clean it too? How difficult is that?
THANKS!!!!
This is the type of thing that I never would have even known to try or attempt on my own without the help of the forum.
THANKS!!!!
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Those GM clamps SUCK. Replace em.
And DON'T remove the iac pintle. You don't need to to clean it, and you probably won't be able to get it back in. I ended up buying a new one for that reason.
oh yeah, smack123, sorry about circleing that bolt, i knew you had that covered.....
Originally Posted by wht_slvr_86
is that the airfoil i hear about or is that the stock gm part
Which one?..., though it doesn't really matter...Everything I've mentioned here was installed by the General himself.
Ok, I have not removed the pindle, and did as suggested - cleaned it in place holding it so the cleaner does not get into the stepper motor.
As for the plenum, any thoughts...should I keep going? Where does it end
This is too much fun. I must say, I am pretty proud of myself.
THANKS!!!!
THANKS!!!!
as for the bypass.. DO IT ... have had mine done now for years.. no problem with it.. i seen adapter 5/8" to 3/4" @ auto value today middle row, near counter. ( 6-7 bucks)if its feasable, you could cange the entire hose. removing the iac should be done with care. when cleaning use carb cleaner, oil it lightly.. make sure that it is retracted enough as not to bottom it out when installing. Read the tech notes on my website.
you will have to reset TPS, iac, as we did the other day....hopefully this will cure the boog you spoke of..
The air foil is removeable, clean behind it, and reinstall.
when I took this picture a couple months back, I wasn't sure I would remember how to put it all back together.....
i live in maryland and it gets down in the teens and zero's pretty frequent at night and i've driven my vette many times like that with no problem. as long as the motor is warm it won't freeze up. the tb gets plenty hot enough even bypassed due to radiation heat.
it's all upto you. personally i've never had problems below freezing.
1. What is the functional benefit of the TB bypass?
2. If I do the TB bypass, what do I do with the connections on the TB - Do they need to be blocked off, if so where would I obtain such a plug or cap?
Hey guys - here are some progress pictures.
With regards to gaskets, 2 of them broke while being removed, and in any event I'm sure it's a good idea to replace them. As for part names, the best I can find is:
1. Throttle Body Gasket
2. Throttle Body gasket (underside) this I assume is the one to connect to the IAC
3. ??? What is the name for the one on top "Throttle Body Plate Gasket"? The one that seals the TPI plate.
Can I get the gaskets through any auto parts store or are they only made and sold by the dealer?
Thanks everyone.
Thanks everyone.
