Spark Plug Wires
Old 03-18-2005, 11:15 PM
Nemo
7th Gear
Nemo's Avatar
Default Spark Plug Wires
Hi All, anyone know where I can find instructions on how to install spark plugs wires in the right order?
bought the car from a friend without the heads, distributor, rotor and plugs installed. thanks!
Old 03-18-2005, 11:25 PM
want2drivemy85
want2drivemy85's Avatar
you should pick up a haynes or chiltons manual. it will explain how to do this, fairly easily. you can find these at most parts stores. this way, you have the instructions handy, right in front of you while you are doing the work.
Old 03-19-2005, 12:56 AM
nobodyunknown
nobodyunknown's Avatar
I always remember the firing order as a phone number.
1-843-6572.Then put the distributor in pointing at #1 with both the intake & exhaust rocker arms loose.On the compression stroke.Or up what ever you want to call it.
On the dist. cap the # 1 plug wire should be pointing towards the right front of the car .Basicly if your looking down on the car the # 1 wire should be about 1oclock.
I dont know if this helps but its basic knowlege.Anyone of your fiends should be able to help you out.
Old 03-19-2005, 03:50 AM
85 500 horse
85 500 horse's Avatar
Or, you can save yourself some money and do it by the trial and error method. If you install each wire simply by guessing, it will only take 40,320 attempts before you are guaranteed to get the correct firing order.
Old 03-19-2005, 12:59 PM
Wayne88
Wayne88's Avatar
This is from the Chilton manual, It applies to my '88.
Most auto parts stores sell these manuals
Old 03-19-2005, 01:08 PM
Nemo
7th Gear
Nemo's Avatar
Hi All, thanks for the help!! will try em today.
To Spark Plug Wires
Quick Reply: Spark Plug Wires
